hi guys im searching for some injectors, prefferebly new ones..
i have a r34gtt with a 500hp turbo and want to get my power upto 300rwkw.
Just wondering what size to go for and where to buy them????
cheers
steve
https://www.sau.com.au/forums/topic/272896-r34-gtt-injectors-for-300rwkw/
anyone got some suggestions????????
550cc im pretty sure mate
just jap or pretty much any other trader on here, just check the trader sales section.
goodluck
Gezza
Ive got 480cc nismo for $600
1 month old just get a nismo reg as well and your all set
whats the reason your selling them, is there anything wrong with them?????
what power were you running with 480's?
Edited by Tough R34
has anyone got close to 300kw with 480's???? would there be a huge diffence with 70cc???
My car got dyno'd at 246kw but that was stretching the stock injectors to 98%
Its now tuned at 220kw with injectors back around the 80% mark.
Nismo don't make any larger than 480cc item for the R34 RB25det neo motor.
I would suggest buying the Nismo 480cc as above ^^^ and the bumping up the fuel pressure (with a FP regulator) twin spray pattern and high impedence, meaning less lag time for fuel to be injected, something like 0.01sec
Otherwise the other options that you have available are:
Highflow standard injectors - approx. $150 each (which aren't the best, can f!ck up spray pattern, impedence etc)
Sard injectors - 600cc or 800cc - they require a collar to be attached and aren't straight bolt in approx. $1200-1400
Blitz injectors - pretty much the same as sard injectors
HKS injectos - 650cc-850cc, requires hks fuel rail - all up approx. $1400
cheers for the info...
are the nismo's straight change over from stock???
has anyone seen 300kw with the nismo's?
i just dont want to get the 480's and then not be able to make that power range....
Nismo are the only direct bolt in, unless u have highflow of standard injectors.
Most of the members on this forum are also saying that 480cc will make 300rwkws.
Just make sure you have a good enough Fuel Pump and maybe the fuel reg
go the nismos n bump up the pressure with a reg. even with nismo injectors ive been told by justjap that u still need to purchase the o-rings. in which case its the same as the sard injectors then. only difference is that sards have a collar (spacer) which sits between the injector and the fuel rail. ive got sards, works a treat :P
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
