I have the following items for sale, PM me if interested, no deliveries, pick up only from Shire area, (Sydney south).
R33 GTR 444cc injectors, (6 off).
RB25 stock turbo, (T3 flange), came off RB20, R32GTSt. Minimal end play, well within limits.
RB20DET stock viscous fan, has ben trimmed to fit intercooler kit.
R32 GTSt air con fan.
R32 GTSt air con compressor, working fine when removed.
Aftermarket FMIC. (R32 GTSt)
FET Turbo timer.
Hi-flow cat converter. R32 GTSt.
R32 GTSt air con compressor mount and idler pulley.
R32 GTSt air con condenser.
All reasonable offers will be considered.
Pls PM me for more details and offers.
Rgds,
Grippy.
https://www.sau.com.au/forums/topic/273156-r32-gtst-spares-for-sale/
You need to post prices dude.
R33 GTR 444cc injectors, (6 off). $400
RB25 stock turbo, (T3 flange), came off RB20, R32GTSt. Minimal end play, well within limits. $200
RB20DET stock viscous fan, has ben trimmed to fit intercooler kit. $20
R32 GTSt air con fan. $20
R32 GTSt air con compressor, working fine when removed. $50
Aftermarket FMIC. (R32 GTSt) 550mmX300mmX80mm. $300
FET Turbo timer. $50
Hi-flow cat converter. R32 GTSt. 2 1/2" flange. $200
R32 GTSt air con compressor mount and idler pulley. $20
R32 GTSt air con condenser. $40
Aftermarket combined front/dump pipe. RB20DET. $200
Splitfire ign coil packs new in box for RB20 or RB26 only. $700
Update of more parts found now for sale.
R32 GTSt stock radiator, $100
R32 GTSt engine crossmember, $100
R32 GTSt stock brake booster, $100
GRIPPY
forum wont let me send PM, im very interetsed in the turbo, is it in good condition, sereis 1 or 2? Do you have the elbow as i ned it to fit to my rb20.
Thanks heaps
Turbo in top condition, I have the elbow. Not sure of series as it came off my RB20.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
