hi gang
looking for someone who is a flash coder to make for the club an apexi powerfc hand controller emulator in flash
i have all the menu shots taken from the manual and i can show you how they go in what sequence
and what each button does etc but im not familiar with flash and would like it is something nice and easy like flash
it doesnt have to do anything, just show specific images based on button click events
i can supply all the graphics, logic, menu names, text etc
just need someone to link it all together in a nice flash object for a webpage
your name will be credit'ed in the powerfc faq
i would like to make this to educate people who don't know how to use the hand controller
or for people who would like a hands on demo of what each thing does
this would help tuners, new users, experienced users and those who may be interested in the PFC etc
please let me know if you are interested
paulr33 at hotmail.com
https://www.sau.com.au/forums/topic/274158-flash-coders-ahoy/
people who make websites in silverlight should be cuntpunched so they don't breed any more stupid people. Just like people who don't upgrade from IE6, or Windows 95.
XHTML or die.
people who make websites in silverlight should be flamin mongrelpunched so they don't breed any more stupid people. Just like people who don't upgrade from IE6, or Windows 95.
XHTML or die.
LOL, wots with u and physically abusing people's private areas anyway :)--> http://www.skylinesaustralia.com/forums/in...t&p=3691676
it looks good...but its early days....thats about all... but then again I dont have vista and most get it because "it looked pretty" 1 week later i normally get the phone call to take it off... :)
XHTML or die.
Well I'd rather make it as a WPF app, but I don't think that's what Paul was after :)
i really dont mind what its written in, as long as it looks ok, is lightweight and any retard can view and play in it
whatever you guys want to code it in, is fine with me, silverlight sounds a bit homo spec if you need to download another client etc
how detailed is the menu anyways? if its not too much of a headf**k as in heaps of steps i could knock a flash thing up for you to embed in a website. Im no pro but if its just buttons linking to other stuff i can do that. it may not be the most efficient in terms of fancy coding but it will do the job..ha
all i need is someone to script the buttons linking between the different images
thats all there is too really ? adam has already sent me something and it looks good so far
its just simple image click this button, show that image and so on
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
