Fitting Bov To Factory Location On R34 Gtt
STYLN
 Share
Guys after buying a trust style BOV recently from JJR i decided to fit her up and do my usual thing in posting the how to.
Here's the BOV i got witha universal adaptor (not needed)
Pic of the factory BOV with rubber pipe removed to the return line. It plumbs back to the intake, though i havnt bothered to plug it yet as im not aware of any reason it has to be.
Remove the factory BOV and you'll find a 1" hole approx into the manifold pipe note the extra vacuum line coz it could get in the way later. Mine went in fine though so its check twice cut once guys...
Overlay the factory BOV on some cardboard then the new one and trace the individual shapes in positions that will suit the layout without fouling the vac line or bolt heads etc. This way you make an adaptor plate that keeps the original stuff close at hand. Then take some 10mm alloy plate and drill, cut file and shave until its smooth and slick.
Here's mine before final filing of centre hole.
And after thats done fitted to BOV using supplied bolts.
Fit her back up with the gasket you took off the factory one and presto!
Run a new line from the manifold to the BOV (i used smaller Blue silicone line)
And enjoy the new toy...
You can see another part of why i aimed it away. Lines up with my vent in the CF hood nicely.
Defected no probs un bolt and return to stock instantly.
Thanks :P
  • Like 1
  • 4 years later...
If you want to line the BOV up with the factory recirc pipe (if you want to use it as a recirculating BOV), then you can drill and tap the factory crossover pipe. Obviously pull it off to do it
I did this with my Greddy Type RS rip off BOV before I went front facing plenum, worked a treat. Then if you want to go back to factory BOV, you can make/buy grub screws to screw into the crossover pipe (if you have drilled right through it). With some thread sealant you shouldnt have an issue
Not taking away from the original DIY, just an idea for people who want to go recirc. :)
Seriously, you cheaped out and bought a non genuine Greddy bov, then had to mod the crap out of it to fit. Why the hell didn't you just buy the bolt on Turbosmart Kompact plumb back for $170 and be done? Even grub screwing the bleed hole in the stock BOV would be smarter imo.
Plumb that sucker back or you will stall constantly, potentially causing an accident, not to mention the fouled spark plugs and black rear bar.
Was that aimed at me?
If so:
It was hardly 'mod the f**k out of it' by drilling and tapping 2 holes into the crossover pipe
it was recirculating
I only did it to check the BOV (which I was just borrowing at the time) worked fine.
I have a genuine RZ now, on custom cooler piping
I'm not sure what the bad reaction was for, It was merely another way to do it if you want to retain the recirc. It's not hard to drill and tap 2 holes in the crossover pipe..... I was just offering some advice
Not aimed at you Callan, Pete was duped into buying the crap bov and left it venting, then thought everyone should be doing it. He should have kept the stock one there, infact Nissan should have welded them in place imo.
My point was made today, as I sat behind an evo8 that flooded itself at the lights. As I was waiting for him to start it, I wondered if I would hear the all too familiar ssq noise, and I wasn't disappointed. :/
Modding your car for street cred and ruining it's drivability... I just don't get it.
All good, I was a bit confused but now that I re-read your original comment, it seems alot less aimed at me now lol, opps
Didn't even realise this was originally from 2009 lol. Thread revival and I got sucked into it. Thought someone would have done a DIY on this before
Alot of us have all been down the atmo BOV route with stock/MAF computer and once you see first hand how bad the car is with it, you dont keep it around for long :) We were all young and dumb once
Edited by 89CAL
 Share
    • It's generally best practise to run 1x run without VCT enabled, then 1x run enabled till redline. Overlay the two torque graphs and you'll find the desired RPM to turn off VCT. Sometimes, it might be even worthwhile turning off VCT earlier control torque/cylinder pressure and using VCT purely to spool the turbo.
    • They sell them in Malaysia for about $4
    • First time I ever have issues with Amazon, but my wife often tells me to keep an eye out for fakes. It finally got me. I wrapped up the conversation with Gates. The gentlemen I was talking to seemed to hate his job but the response time on their technical support is outstanding. He stated that the hose is marked with some variation of "SAE J30R10" but that if you only purchase a 1 foot length like I did, it is possible to get a cut between markings and have a blank hose. To no ones surprise, he stated the swelling and "gummyness" isn't normal and to replace/buy from somewhere else (He mentioned NAPA). I'll toss a small end of the new one in gas for a few days before pulling the hanger out again, just to be safe.  Hose should arrive Monday. For those running multiple pump in tank hangers, you know the joys of getting them out and back in. I'm surprised I haven't destroyed my level float yet.  Lastly once I wrap all of this up, I'm planning on hitting the dyno again in 2 weeks while I'm on vacation. I realized recently that my VCT is set to turn off at 5000RPM. I'm surprised it wasn't increased while I was on the dyno last. I'm expecting I can increase it to ~6500RPM, if not more. Should hopefully get another 15-20kw out of it. I also want him to revisit my knock thresholds. I'm occasionally getting false knock around 3000rpm.
    • I don't believe you.
    • All jokes aside, OP they're just called R32 oem rims as you said. The Nissan engineers back in the late 80's loosely copied the design from the Koya Driftek which was designed and produced about 18 years later.
