Hey guys,
I just installed a profec B spec 2 boost controller in my car.
The solenoid is definately connected to the wastegate and the 'compressor nipple' (which was working fine at 8psi without solenoid so i know its a good source)
Power is connected, the unit lights up, and appears to be working properly.
Boost source to controller is good, it's connected with a Y piece to the boost guage right beside it, and the profec shows the correct boost level.
The cable that goes unit->solenoid is definately plugged into the back of the unit and the solenoid.
I've put the unit on hi, and turned it up to 50% without changing other settings, but it still just sits at 8psi.
In case i'm a retard and did it wrong, i swapped the hoses into the solenoid, but this also made no difference
What can I do to troubleshoot?
Thanks,
Isaac
https://www.sau.com.au/forums/topic/274752-profec-b-installed-help-please/
  predator said:
Sure you are setting the boost and not the gain?
Yea, positive :banana:
There is a third 'air hole' that is covered, i think it's used if you have an external gate, but the instructions say (after re-reading them) to remove covers off all holes, so i've removed that, will test drive this afternoon to check :)
  islade said:
Yea, positive :thumbsup:
It should work now that cover needs to bleed to atmoshphere otherwise you will not have control of boost from what i can remember with mine let us know how you go.
  islade said:
There is a third 'air hole' that is covered, i think it's used if you have an external gate, but the instructions say (after re-reading them) to remove covers off all holes, so i've removed that, will test drive this afternoon to check :thumbsup:
Yep, there's your problem.
  • 5 months later...
anyone have any more tips and pointers ive just installed one in my car but i cant seem to get it working, and i have tripple checked the connections are correct maybe ill try removing the cap also
and i have no idea what to set the gain and settings on argh doing my head in
I installed this along with a new turbo, which was having wastegate problems, so i needed to unblock that piece, but it still didn't work until i got the wastegate fixed :)
The cap has to be removed, that is the whole point, how is it ment to bleed out air if it is blocked.
Yeh i've got a Profec Spec B II as well, Hightboost 17psi and low boost 14psi. The caps have to be removed for the air to bleed out. To make your boost go up you should move up the gain %% , your boost should go up.. if its not then have you checked your actuator?
heres a pic of mine this is how mine is connected.
