Hey guys,
I just installed a profec B spec 2 boost controller in my car.
The solenoid is definately connected to the wastegate and the 'compressor nipple' (which was working fine at 8psi without solenoid so i know its a good source)
Power is connected, the unit lights up, and appears to be working properly.
Boost source to controller is good, it's connected with a Y piece to the boost guage right beside it, and the profec shows the correct boost level.
The cable that goes unit->solenoid is definately plugged into the back of the unit and the solenoid.
I've put the unit on hi, and turned it up to 50% without changing other settings, but it still just sits at 8psi.
In case i'm a retard and did it wrong, i swapped the hoses into the solenoid, but this also made no difference
What can I do to troubleshoot?
Thanks,
Isaac
https://www.sau.com.au/forums/topic/274752-profec-b-installed-help-please/
Sure you are setting the boost and not the gain?
Yea, positive :banana:
There is a third 'air hole' that is covered, i think it's used if you have an external gate, but the instructions say (after re-reading them) to remove covers off all holes, so i've removed that, will test drive this afternoon to check :)
Yea, positive :thumbsup:
It should work now that cover needs to bleed to atmoshphere otherwise you will not have control of boost from what i can remember with mine let us know how you go.
There is a third 'air hole' that is covered, i think it's used if you have an external gate, but the instructions say (after re-reading them) to remove covers off all holes, so i've removed that, will test drive this afternoon to check :thumbsup:
Yep, there's your problem.
  • 5 months later...
anyone have any more tips and pointers ive just installed one in my car but i cant seem to get it working, and i have tripple checked the connections are correct maybe ill try removing the cap also
and i have no idea what to set the gain and settings on argh doing my head in
I installed this along with a new turbo, which was having wastegate problems, so i needed to unblock that piece, but it still didn't work until i got the wastegate fixed :)
The cap has to be removed, that is the whole point, how is it ment to bleed out air if it is blocked.
Yeh i've got a Profec Spec B II as well, Hightboost 17psi and low boost 14psi. The caps have to be removed for the air to bleed out. To make your boost go up you should move up the gain %% , your boost should go up.. if its not then have you checked your actuator?
heres a pic of mine this is how mine is connected.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
