i have the ogura unit same as rev210
it use to vibrate in 4th and 5th between 1500-2000rpm. I was told its a balance issue but i also tend to think it just took awhile longer for it to bed in as i don't get the vibration anymore.
and yes do it, response is awesome
I have no vibrations at all. I torqued the bolts up in proper 'star shaped' sequence to ensure the perfectly ballanced Ogura flywheel sat flush on the mounting point.
Craved,
Less acceleration up a hill? Rubbish! : A lightened flywheel equiped car will completely kill a car the same without a light flywheel. More so in the first few gears.
Bottom line is that the light flywheel equiped car out accelerates a standard flywheel equiped car up a hill or down a hill, into a headwind or going with the breaze. They are a dead heat off a cliff tho' (if your into that form of racing save your money).
The easy to stall part is because of the heavy clutch. I don't have a heavy clutch just a good 9 puck ceramic friction plate. Therefore no one has problems stalling my car.
i agree with you rev210, no chance of less "acceleration"! however i did say momentum, thus in a high gear in lower revs up a hill the lighter flywheel will drop revs quicker! Especially in a full/heavy car!!! thats all i was saying!
Guest darrinspencer
just for everyone's knowledge
Direct Clutches in Brisbane 07 3862 2680
Can do a lightened flywheel that weighs 5kg for $440 retail.
compared to others that are heavier and cost a fair bit more, makes these great value.
they also do a clutch kit
2800lbs organic clutch plate rated at 350rwhp or 260rwkw for
$530 retail
i have decided to put both these in my car.
I had a 'lightweight, cross drilled, balanced and machined' flywheel in my last car, i didnt get any vibration, and there was a definate performance increase...not a lot, but it made the car feel slightly sort of ligher...(more power i guess..)
the car also held speed better on a straight. ie. before it would slow down without pushing the accellerator a bit, but after you wouldnt have to push the pedal and it would hold speed.
Maybe you should find a cross-drilled one...apparently works sort of like cross drilled brakes, lessens the effect of a clutch overheating and slipping.
Originally posted by Richelieu
For piece of mind, billet alloy flywheels weigh in at less than 1 kg.
crap, a flywheel will not weigh less than 1 kg, a bike one maybe not a car tho.
i got a 4.8kg (ogura chrome molly) flywheel also and its makes a great difference in acceleration and i dont have any vibration problems. U will get vibration problems if u try lighten the stock flywheel.
I'm also considering a light weight flywheel but after speaking to perfomance shops etc I'm a little undecided, coz I want to keep everyday drivability.
Is there a severe decrease in bottom end torque? Apparently lightened flywheels are awesome above 3k rpm but suck for every day city driving?????
Altho siksII describes otherwise, I have also been informed that a lightweight flywheel will also cause the engine to drop revs a lot quicker when you back off the accelerator.
These 2 theories seem to make sense to me as less weight = less effort to make it move, but less weight = less momentum to keep it moving.
Thats right, my car revs much more nicely upto redline and i havent noticed any loss in low down torque.
Dont you hate when people give things bad reports when they would know shit about it or even driven a car with it??
yeh....deceleration will be quicker..not the car but the engine speed......its pretty simple lightened flywheel = quicker accel, quicker decel...
probably have to clutch in bit sooner and city driving will need bit more throttle than usual....(bumper 2 bumper)
http://www.aussiefrogs.com/articles/406sup...os/photo_4.html
third coloum, halfway down, says flywheel weighs in at less than 500g.
What the???? You are quoting an article about a touring car with an aluminium flywheel, that requires to be shimmed up every race to maintain contact, with a street driveable alloy flywheel that is designed to not need shimming???
you also stated "For piece of mind, billet alloy flywheels weigh in at less than 1 kg."
I didnt see that anywhere in the article no reference to billet or to alloy or to 1kg.
In case you havent noticed, this thread is about lightened flywheels for a skyline - find one that is available in alloy under 1kg designed for use on the street - you wont. Ogura is the lightest I have seen, and it weighs 4.8kg.
and that article proves what? do u drive a touring car on the road and pull the flywheel out everyday??
Ok guys ill try explain how the lightened flywheel works in laymans terms...
Lets say u are going to push a box on the ground. If u have a light box, it is easier to push and quicker. If the box is heavy, it takes more time.
This can be related with the engine and flywheel. If the flywheel is light, the engine can get to higher RPM quicker, and if the flywheel is stock/ heavy, it takes the engine longer to get to higher RPM.
What this all means is that you can accelerate quicker due the the engine being able to rev quicker. This is the principle reason that people change flyhweels to lightened items. The only downside is that because the engine can increase in revs quicker, it also decreases in revs quicker.
Hope that makes sense to those confused.
Fair enough. You guys are right.
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
