Shops that sell it early run the risk of being fined. thats's why very few do it. used to be done much more in the past, but these days you get people showing off like above posting pics of the game with the reciept, which usually has the store details which gives sony all the info they need.
Gona pick it up 12:01 from 24 hour kmart tonight. I think its been really overhyped and our expectations have been raised way too high. Hope im wrong though.
This guy seems pretty depressed playing it lol. http://au.gamespot.com/shows/now-playing/?...rismo_520101122
Edited by S4LVA
agreed, i think my expectations are to high and after watching that bit of gameplay i think i might be a a bit depressed lol, but we will wait and see.
Damn 20 mins. Was hoping i'd be able to play it before getting some sleep for work lol. Yeah I skipped through the video and it just looked like any racing game. He hit another car and it didnt spin out or even skid it just swayed a tiny bit and kept driving normally. At least now my expectations are way down so when I play it itll seem good :P
lol 20mins is a lie! it has been going for 40mins now!
now its on 4seconds which was more like 2-3mins lol
im not going to cry if its not everything i expect. the interiors and other premium cars will come. im just happy its coming out.......although i cant pick mine up till saturday!!!
and aslong as it drives well with the G27 ill be happy. gotta be better than driving the same cars around the same 4 tracks in prologue like we have been.
installing now :P so how long did install take u guys?
fucking forever!
indicated 20 minutes = nearly 2 hours
indicated 18 minutes = over an hour
indicated 12 minutes = an hour
indicated 1 minute 10 seconds = 45 minutes
indicated 8 seconds = 15 minutes
i was pulling my freaking hair out. now its finally done. fuck this im going to bed
Edited by jonboy
wow. mine is the original 60gb console. maybe the new ones are faster.
also has anyone seen anywhere local that you can buy the HKS racing controller? i found This Page but i think thats from the states. i asked at ebgames last night and the guy had never heard of it. i also heard its not wireless.. i might cry if thats true
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
