yeah the photo thing is awesome, got my old school Kombi, dumped, gloss black with a big ass exhaust.....will post when i can. some of the filter options etc are really cool too.
im still waiting for my 400R, how much was it if you can remember?
i never seem to have more than 200k credits.....every time im in the used car lot i find something else thats old or just dam cool. 70 cars and counting (got the 50 car trophy in less than 24 hrs)
Jon, what cooling do you use for your PS3?
I just sit a pedestal fan in front of it and angle it to the lower front of the console (40GB version).
Doesn't even turn it's thermal fan on (sits in a poorly ventilated tv cabinet).
i haven't used any cooling so far. it ran sweet for 3 years (bought on release day) it sat in a closed cabinet with no venting for about a year. the first time i fixed it there was heaps of dust clogging up the inside so i cleaned it all out real good. the last couple times have been minimal dust build up, yet it's still happened. i've just pulled it all apart and fixed it again today and i ordered one of those usb fans that force more cold air in. has anyone used these and seen a lack of failures or anything?
on the 40gb one there is a auto dest blow out function... i've used it once... just turns the fan on full speed in an attempt to blow out crap. I've noticed my ps3 is running warmer than usual... i'll do that again soon and maybe look at a cooling option if needed.
You activate it by holding down the eject button and turn it on from the main power switch at the rear
i did the final top gear challenge last night. took me about 10 attempts to finally complete 2 laps. the first time i got DQ'd at (i think) the follow through (right hand corner before the tyres and back straight). i ran over the painted lines (going so slow you don't even think about it because the faster cars understeer a bit as you turn in so you are ok). second attempt i got to the first corner on the second lap and got taken out by one of the cars coming the other way and DQ'd (since there is a group of cars that is lapping half a lap ahead). 1 or 2 other attempts i made the same mistake at the follow through. i think one i cut the corner on the start straight a little bit (may have even been overtaking a car and got rammed off, can't remember).
but finally i managed to complete 2 laps without being DQ'd to complete the event. got gold (extremely easy to do). even silver is easy. i was into 3rd place after the first lap. 2nd by halfway through the 2nd lap and into first at the end of the back straight. you have bronze after about chicago on the first lap though. the car in 7th gets taken out on the first corner, then on the braking into the chase you can getinto 6th and the car in 5th gets taken out, or runs wide into chicago as well, so by the time you get to the hammer head you have the bronze.
I'm struggling on the 2nd topgear challenge... that lotus is horrible, and the AI of the other cars is fkd
any tips?
If you simple want to pass then just take your time and simply overtake under brakes. remember you have 2 laps to do it. don't try and overtake everyone in the first lap
yea the lotus challenge was tricky, but yeah mads onto it. eventually you'll get to learn what pace you need to be at. if i remember correctly i think i was in 3rd place going into the 2nd lap and took 1st going around hammerhead. unless theres an AI car in front i still have a hard time finding gambon after that long straight, just cant see shit lol maybe i need a bigger tv?
and while doing the karting challenge are you guys looking out for banana peels and turtle-shell missiles? or is it just me..
well it was just you, but i'm sure i will now. i actually like the go-kart challenge. it's a bit of a pain that there's no go-kart races in the A-spec section.
haha, yeah I ordered one last week so should have it any day now, hope it makes a difference (can't see why t wouldn't).
My PS3 has only started using the exhaust fan with Borderlands and GT5, not one of my other games seem to heat it up to the same extent (even with the cabinet door closed)
theres always online. nextgg organised a race for tonight.
http://www.nextgg.com/forum/viewtopic.php?f=101&t=7140
i'll be joining if i can remember
yeah i'm too lazy (and disorganised) to race in online races like that one
i heard it was cos your a shit driver and wanted to save yourself the embarrassment. anyway, turns out i wont be there tonight. fuckin RL messin with my gaming time.
So when does the top gear track become selectable for practice &/or online races???
Get gold in the top gear combi race. I have heard people have got it for finishing bronze on the lotus race as well, but I dont know that for sure.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
