Hey guys,
Whats the deal with the tradng cars thing? I cant work out how/when to do it.
cheers
Its simple, ,all you do is select the car, then select the give to friend option, and you can use the usb method if you want to keep the car as well.
So it loads the car onto the USB then plug into another PS3...or different user....too bad no-one close to me plays GT5 lol
is it just a straight give away or is there cashola involved?
....I'm such a noob lol
  • Like 1
nope
you give the car as a gift
they can send something back if they like, or they can not :P
the usb method is when:
copy your save onto a usb
gift car
delete save on ps3
copy save off usb to ps3
still have old car you gifted away :P
but now you cant gift cars over 1mil credits......
You copy your game to a usb, then you send the car, then you copy from your usb and it overwrites the save on the console then you have sent a car and you still have it, and no there is no cash involved unless you are dealing with people selling X1's on ebay.
Also the 1 million cap has been lifted for now.
nope
gift car
delete save on ps3
This step isn't really needed and potentially could lose everything for you, just copy from your usb it will overwrite.thumbsup.gif
has anyone managed to win the X2010 via the seb vettel challenge yet?
i swear to god i cant even finish the first lap on the first track. yet alone do two laps and get gold doing it?! jesustittyfckingchrist its hard and i've aced almost every other challenge on gold
Edited by jonboy
yeah when i first tried it a month or two ago i think i managed to finish once but missed by about the same as you. at the time i blamed the fact that my tv was a pathetic 26" and i was sitting a half mile away from it so my ability to see things was questionable at the best of times. so the other day i bought a 40" tv for my room and i sit about 3 feet from it lol so seeing things now is not the issue. but alas, has not made a difference in my (in)ability to dominate the seb vettel challenge
Edited by jonboy
^^^ you guys read my mind....only given it a few goes, but (esp with my wrist in a brace) got no where...dam that car is nuts. only finished the first one once...and that was 3 seconds off bronze. i know i can do better...but not the 2:09 you need for gold. even the demo you can watch falls short of gold.
not gonna frustrate myself further with it till i have full movement of both hands.......
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
