Have you done like the wind ?> The final one ?
Basically, Buy a Corvette ZR1 or whatever the are from CHEV.
take it to GT AUTO
Perform racing modifications.
This should give you pretty much all the expensive shit in the tuning show (weight reduction etc etc)
Now go and fully tune the engine as far as it can go.
Buy racing softs.
You should now be able to win most races.
Win the "like the wind challenge"
You with the Toyota Minolta 88C-V, Give this car the biggest turbo upgrade and racing soft tyres.
You now have a car to beat any cup it is eligible for.
does rebuilding the engine and chassis actually achieve anything ?
I don't want to do a full 6 hours of testing at the ring to determine this.
beaten all races bar the bottom 4 of the enduro's and the Formula GT world championship.
rebuilding an engine will see you get an increase of hp (takes it back to what it was stock), so if you have a car that you have used a lot and it is down on power compared to when you first bought it and an oil change still doesn't take it back to full original power then a rebuild will.
don't know about the chassis one though.
take it to GT AUTO
Buy racing softs.
Well didnt work....will have to slug it out to 5mil credits the old fasioned way
Yeah Zebra,
What exact car did you buy.
If they are catching you make sure you play with gear ratio's depending on the track.
I found I could go a lot closer on Daytona Infield circuit and then of course open it right up for Indy.
It wasn't a struggle, it should be a pretty easy clean sweep for you.
the prob I have is getting past the cars through the infield, no where to pass/or you just get bumped off....it shits me that there is no quali...fkn over starting in 7th all the time
Rolling starts also shit me to tears
Im almost to 20mil thanks to remote bspec haha
hahaha, yeah thanks for that. i log in every week or so and retrieve the prize money i've gotten thanks to you and a few others. if i have time i run a few races to pay you back a bit too.
zebra i sent you a friend request on PSN ages ago. i could've earnt you a heap of money over the past few months had you accepted, LOL
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
