very well organised event and was happy to catch up with a few people....sorry i had to bale really early as i was in a very very bad state.....but good day all around.....so has anyone posted up the whole days power figures???
Oh you awake now Krishy? :)
  • Replies 443
ah dont even go there Damo lol....man oh man what a hectick friday night it was....i think i had mentioned earlier that i might just be in a very bad state...which it ended up being lol....my insides are hating me
thanks to all who organised it!
was a fantastic day!
i am really happy with my consistent 240rwkw, hopefully by the time the next dyno day comes around i can get the car to climb over the 300rwkw mark.
i'll have to remember to wash the car next meet!
Brezza
i wanna know how i lost 10kw by adding a new fuel pump
Running richer due to the increase in flow. Thats half my problem too. Do you have an adjustable FPR?
it was the same dyno each time its been tuned....174.5 with n/a pump and reg.....then 150 with 2nd hand 040 and vlt reg....then 140.1 with new 040......i just dont get it...i might hook up my n/a reg and see how that goes for the time being..until i can afford a malpassi blacktop and a remap
I lost 15kw by replacing coilpacks. Differences between dyno I guess - it better be and not be something wrong with the car haha
I dont think that dyno read low Vu.....i made 214 and previously the best was 211....but i am eager to find out as to how the f**k can you loose 15kw by getting better coilpacks???? i gained power by getting splitfires
that animal being Pete, i swear he ate at least 6 sausages with bread
didnt he say he was going home to eat his wifes lamb too....lol ? hollow leg pete ?
sorry nugz I only have this shot of your car I think
what coilpacks are you running now Vu
i think hes running yellow jackets like me, i got 189.6 rwkw on 10psi (might have spiked higher, no readout on dyno chart). last dyno run i had 173 on 13psi without coilpacks or dump pipe.
what plug gaps you running vu?
my dyno chart is once again flat mid way... needs a good tune, think there's a few kw in there somewhere too, have a feeling it might crack 200 on 12psi.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
