im am very close to completing my rb26 powered s15, its fairly full house and plan on running 9's
ive just got few questions on what you more experienced guys can tell me......
i have a motec m8 pro, which is a mad ecu, but im unsure what to run...
it only has 4 direct fire ignition outputs and can obviously run wasted spark....
my tuner tell me i must go cdi with mecury coils... another dude told me i can set up splitfires to run with a motec cdi system???
what do yous rekon??
https://www.sau.com.au/forums/topic/275163-ignition-system-rb26-650wheel-hp/
If your tuner tells you to go a specific route, and you trusted him so far with your build, would you turn around to him and tell him to set the Spitfires up because another dude told you to go that way?
How would he take that?
If he's proficient in tuning M8's, I would take his advice as he works with them and would be talking from experience.
I'm not being a dick here, just the devil's advocate so to speak. :P
ive seen other setups make significant power without going as extreme as a cdi system, my tuner is like a high maintenance woman, he likes everything expensive...
im trying to save cash but not cut corners 2 much....
a cdi system is worth 2g inc coils,
why would i throw 2 grand if i could do the same job or at least similar and get the same result for something that costs 500 bux??
Edited by den001
cdi meaning 'capacitive discharge ignition' yes?
where by a unit that contains a bank of, probably electrolytic, capactitors supply the charge to each coil pack??
or does this unit feed a charge directly to the spark plug?
have a rough idea of how this work but not entirely sure.
in theory this system makes perfect sense for great spark power, as any one who has seen a large capacitor instantaneously discharged can verify.
^ what Ash said
heaps of full-on drag GT-R's in Japan just use the standard direct-fire coil setup with the addition of an HKS Twin-Power module
i was leaning towards that as i would also save cash on wiring....
can the plug gaps be opened up with this setup?
why cut corners on ignition when uve obviously spent an absolute motsa on an ecu and probably everything else in the car.
personally id go m&w cdi, m&w coils & magnacore leads. last time i spoke to m&w total in parts was $2350, that included an installation kit, pro 16 cdi (youd prolly have to use a different cdi seeing u cant use direct fire) 6 coils, and 6 custom made leads (leads made by magnacore which m&w recommend)
also, why did u chose an ecu that doesnt use direct fire ignition? :P
Spot on Shane...
Sell the shit and buy the real stuff.
fully wired two of these complete set-ups in drag cars while in QLD.
1 x Vi-PEC V88 ecu
2 x M&W drag 6 igniters
6 x M&W coils
one car runs 18 1600cc injectors drinking methanol and ran a 6.71 @ 209 MPH....no hint of a missfire from fireup to shutdown. The car in question had massive missfire issues before i did this instal. Idles like a baby and screams at full noise like a banshee.
Can do a deal on this stuff if you get me to do the instal...a lot of the guys at the Winternationals commented on the quality of the wiring job.
The above set-up is a bit OTT for 650hp....my engine makes around 1000hp and i use splitfires and the hks box with std igniter. I use a Vi-PEC V88 direct fire ecu though...bit better than the MoTeC.
Edited by DiRTgarage
the motec is direct fire..... you should know that, i said it only had 4 outputs,
i was going to use m&w ,m&w now do a 6 channel cdi system which only uses one ignition output to direct fire all 6 cdi channels, only for motec ecu's though
costs 2grand including coils
no need for ignition expander....
i want something sufficient enough to do the job properly and "reliably" i have acquired the computer for nothing so may aswell use it...
i asked the question because ive seen and heard of many many high powered cars running more basic systems rather than a full blown cdi system....
Edited by den001
u knew what i meant though :P
well theres ur answer! get the m&w setup and never look back :P
To get around the waste spark issue you could purchase a motec ignition expander found a price on CAPA website for $340.... I run standard ignitor and splitfire at around that horsepower without problems. If you have spark issue down the track do what dirt does drop in a twin power....
im a tight ass....
whats a set of splitfires worth and that hks box???
cdi is 2 grand complete
will there be much of a price difference
sweet as,
ive been doin some reading and there are some negatives in running a cdi system, ive also been reading about the hks box and it seems to have the best of both worlds.
runs in inductive and cdi modes automically........ hmmm hard choice....
Edited by den001
sweet as,
Ive had a 2 M800's come in lately running stock coils with various amplifiers making high 500rwkw's and one making 522rwkw with the motec cdi and they all tuned up the same (no spark issues), i did not wire the ecu's so am not 100% sure on the specifics without looking into it, but i cant see you running into any issues especially if your tuner knows his motec gear.
i must admit it was nicer tuning the CDi's as they would ignite stupidly rich mixtures during setup etc and saved me time not having to change plugs :) Just for the excercise i did bit of a test and the Motec CDI could ignite mixtures all the way down to the limit of my wideband on 1.1mm gap using fine point race plugs.
Edited by URAS
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
