Just fitted a boost gauge to my M35 as the dash mounted one doesn't work. I found the boost sitting on 16 psi from just over 3000 revs, then dropping to 13 up high (probably due to the compliance cats, all 4 of them.) is this normal? I thought these cars had 2 stage boost. I cant see any mods to the solenoids or piping?
https://www.sau.com.au/forums/topic/275609-m35-boost-level/
  • Replies 80
there is a solanoid that controls boost, its just under the engine cover on the right....
as for boost dropping off, its because of a few reasons, yes the exhaust is restrictive, and im guessing that the turbo is out of its efficiency range that high up in the revs.
your car is an RS? you have an aero kit with fog lights. maybe the fogs were optional with aero?
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668696
Get rid of that exhaust ASAP Scott.
It will help kill your turbo (as it did mine) and set you back a couple of grand.
Yes they were :)
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668706
Yep, an RS four. I havent done the fast check yet as the version I found was only up to 01, but the options seem to be hardcoat, aero with lower and lowbeam fogs, factory hids working and factory tint?
I would like to know if it has LSD also.
If anyone gets the chance to plug it in, its : NM35-304741
Also, I was surprised to find the aluminium bonnet. Very nice.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668731
Tint is standard across all models.
For some reason, FAST is not displaying any factory options.
I can tell you that you car does not have HICAS though.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668737
Aero kit could have been put on after I guess?
Car came with what seem to be Nismo 17x9.5 inch rims, rear wing too.(part of the kit?)
Are all m35 lowbeams adjustable from inside? neat addition.
Could have.
So you have LMGT4's on that thing? What colour (Black would be ace)?
Rear wing will probably be from the Nismo body kit as the Aero kit did not have one as far as I know.
Yep, all headlights are adjustable from inside in 4 (?) stages (0, 1, 2 and 3 - the higher the number, the higher the beam)
Edited by iamhe77
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668757
nice ride mate.....black rims look awesome...good contrast.....have you figured out what suspension you have because it does not look standard. As for the boost mine used to start off at 16PSI and bleed back to 12PSI even after the exhaust was done.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668817
Ok, it seems there is no 2 stage (unless you switch to snow), with masses of pull from 3000. 16psi seems high for standard, do these factory turbos have a ceramic ex. wheel?
It seems like the throttle has a soft action at launch, there is no way to spin the tires even on dirt it seems, It just pulls away like its got traction. Do they all drive like this? If so, bring back the good old cable I say.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668854
Springs: Standard rears? King front.
Shocks: Stuffed :(
I'm getting a turbo back 3inch stainless system fitted on Wednesday and as soon as my tax is done I will probably import a set of HKS LS+ coilovers. That should get all the issues sorted.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668869
Your RS Four will put torque to the front wheels at a slight sense of traction loss from the rears. And 16psi is about on the mark. I dynoed my car and it peaked at about 15.5, then dropped off.
Feels soggy (a ramped feeling)taking off untill 3000 then madness. If I back off after a boot, the gearbox seems to hold its gear too. The auto probably needs a service.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4668976
But it does give you the extra push to go the whole hog and get a high-flow :(
From what I've seen, the Aero is NOT put on FAST, my car has the factory aero kit and FAST does not mention it, I don't think
Iain's (ziel20l) had anything on FAST in regards to his kit either.
You driving in Automatic mode I assume? Try manual shifting, it's must more fun :)
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4669117
Are you SURE?
My M35 RS4 is 100% stock, haven't touched the car mechanically except servicing and I changed the stereo. According to the factory guage its maxxing out at ~0.8bar which is under 12psi. That sounds more likely. I've never heard of any Nissan coming out of the factory with more than 12psi except for the new gtr. and even the aussie version of that runs 12psi.
You may have a modified exhaust/turbo or intake?? Maybe pressure is being leaked somewhere, causing the wastegate to stay closed longer?
It is a ceramic turbo - so it seems very unlikely Nissan would design the car running higher boost than the turbo can handle. And we all know that ~14psi is the physical limit of the ceramic turbo.
https://www.sau.com.au/forums/topic/275609-m35-boost-level/#findComment-4669144
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
