Hi guys,
Just wanted to know if it is possible to cut the original bonnet to have a scoop/vent similar to those ones you see on the Evos?
I saw 2 R33 Skylines today with a air scoop sitting above the air filter. Which gave me a similar idea to do for my car as I still have the standar i/cooler and can't run a cai.
But I don't really like those hood sticking up (no offence), so just want to know is it possible to install a vent instead like the ones you see on Evos and even on R34s.
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/
I think the r34 ones you are talking about are just part of the style of the bonnet - aftermarket ones. None of the factory bonnets have holes / vents in them...
But the Carbon Fibre ones like R34GTT-R's one have plenty of ventage :D
here's an example:
BTW, this car doesnt belong to anyone here AFAIK!
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-578774
I think skylineakt was talking about a scoop for cold air intake rather than vents for getting rid of hot underbonnet air.
Sort of like some drift 180sx have the little intake above the headlight.
I think this would be a good idea, better than running a CAI from the front bar. I think ive seen a skyline with a nissan patrol turbo diesel intercooler scoop used for this purpose, but i cant remember where exactly.
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-579447
Yeah, yeah. That's what I'm talking about. The little vent that you see on the eye lights of the 180sx. Like the ones on JMS 180 drift car.
I want something similar to that but cutting into the bonnet to get some cold air.
I just think that it looks cleaner than the scoop.
I don't think cutting the hole is the hard part, but getting the extra inverted vent to blend in with the pain/bonnet.
Anyone has any idea?!?
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-579460
Sounds like you'r lookink for a NASA vent.... set into the bonnet rather than poking up above it.
If you want them on a stock bonnet you will need to have them
cut and fitted into the bonnet or find the ones you want and have them fitted.
lifting the rear of the bonnet is just a "rice" thing the base of the windscreen is a high pressure area ....so no good for venting hot air from under the bonnet.
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-579461
hmmm :confused:
This is what skylineakt said:
Tell me then skylineakt, what have you seen on an r43? I know what you are talking about with EVO's, they virtually all have some type of bonnet vent but a 34? where? it must be aftermarket?
:shrugs:
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-579789
I know no skylines come with bonnet vents, thats not what i meant, i meant an aftermarket CAI vent, like a NASA vent.
That way air goes into the bonnet not out like a bonnet vent like in the pic.
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-580564
Ok I think the R34 vents I was thinking off is actually a heat vent, venting off the heat from the engine and not a CAI vent.
But it is the same vent but facing in the opposite direction. Like the 180sx headlight vent on the left hand side of the car.
Will it be a big job for them to mend one in??
Like with the paint etc??
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-580751
i've seen a couple of different types aaron.
theres a purple silvia which has three nice cut outs on the bonnet above the filter which are meshed up. looks good. nothing above the bonnet or attached, just cut outs...
or at places like jr, jetspeed, they sell those vents u are talking about. you can get any body work place to cut the bonnet and mount the intake.
i was planning on doin one above my air filter using the ones that JMS sell. evo looking ones. i only want one above the air filter, not both, but they only come in pairs... :(
https://www.sau.com.au/forums/topic/27561-skyline-air-scoop/#findComment-580899
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
