I'm starting to doubt it. Here's some pics.
Problem is he was driving a 1 million pound Ferrari, which i think is his own car, cause he was the only one to get a black FXX. So wouldn't be surprised if its a set up and just a once off.
Killed the lap record though :-)
http://www.dailymail.co.uk/tvshowbiz/artic...Schumacher.html
8 stigs hmmm, makes sense different one for when another is busy, also I vaguely remember an episode where Lewis Hamilton beat the stig in something (can't have been schuey at the time, I refuse to believe it was schuey in that episode!)
Edited by DaGr81
I like the theories of multiple stigs. One theory suggests that it was the car company factory test drivers who would race the cars around the tracks - this would make a lot of sense. Who would know how to drive a car better than a factory test driver?
Edited by ras1983
To be honest, I don't think the stig is anyone ridiculously famous.
They don't need him to be... All they require is a talented driver (of whom there are PLENTY in the UK) who can bang out consistent lap times for comparisons sake.
Come on guys. Its a beat up because the new series is about to start, simple ratings grab
Series has already started 1st episode aired early this morning, the other thing is that's actually his own Ferrari there is more than one black one but his car has no stripes whereas everyone else got stripes (white racing stripes) plus he got special wheels and special interior which wasn't available to anyone except him, plus the fact that they had made all 29 of these cars and #30 was specially made for schuey, why should he let another person drive it when he himself a f1 legend can do it?
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
