can we not have a le mans start... they are sh1t and last time we had one 2 people got pulled into the pits for not having their helmet strap down up correctly (one being me who actually had it done correctly)
or have a le mans start but with helmets already good to go...
  • Replies 372
Posted Images
Homo talk - Check
Drug Slagging - Check
Bogan Bashing - Check
Slagging of Paul "I am so Awesome" Cornes - Check
Chopping a mates grass at the track - Check
Paul Brockbank Mowing Mention - Check
Le Mans Start - As sure a the sun rises in the East and sets in the West it will happen.
Whilst I love feeling up roookies, I'll stick to my co-driver thanks :P
Can't argue with that. Defending... fastest lap (apart from that guy who was a proper-like kart racer).
That means nothing though as the kart was the let down last time. :P
Whats the Brockbank Mowing Team? :P
Edited by Topaz
You just want to go for a thunder down pit straight don't you Mick, if only you could go that fast in a kart!
You fucking know it...... :P
Oh, If I remember correctly..... We finished in front of you didn't we????? :(
Oh, If I remember correctly..... We finished in front of you didn't we????? ;)
We all know that was purely down to sabotaj and had nothing to do with your lack of driving prowess :(
I rang the stig, He wasnt available, has some TV duties in the UK to fulfill, whatever they are, but in the seriousness of the situation he is sending his partner along instead.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
