  • Replies 372
Posted Images
My karting injuries and pains:
I have bruises and possible fractured bones at the bottom of my shoulder blades.
My fingers and forearms are sore and bruised
The tops of both my arse cheeks are aching
The inside of my right knee is bruised
My little toe on my right foot is bruised
Very sore right now. Had a hard time sleeping. :down:
But through all the pain, the thought of that trophy sitting at your place will make it all worth it :D
my left kidney felt like it had been kicked in after i got out of the kart (one of the disadvantages on being slender) but that went away over night
apart from that only some slight arm stiffness, which i think is pretty good for a 45min stint
must be the 4 daily visits to the gym :down:
Edited by Cerbera
Wow.. other than my shoulders being a little sore, no injuries. Mattley had some wicked blister thing on his back from being a skinny cvnt.
haha yeah same thing happened last time, good thing you rubbed it better later and the reacharound was great also :down:
congrats to Paul and Tom we were only just behind you was a close race
must be the 4 daily visits to the gym :D
Bet thats the first bit of stiffness you had in a long time :down:
bubba where is the lap time love :down:
Need ego boost do ya ??? show every one how cool you are ???
lulz.
I think Steve Jones had the fastest laptime of the night with a 57.7!
Just gotta remember my keys next time I go for a smoke so I can get them out of the car.
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
