depends on the store, but ull find a lot use platform lifts, u drive over them (ramps), and the square platform between the wheels raises in the middle of the car onto the rails, they usually just put little blocks of rubber under ur chassis rails.
If its on a two post hoist they will jack the car up at put the arms underneath it like that.
Used to work at Sinergy Motorsports and every 2nd car I'd have to jack it up to fit it on the hoist, what a fcvking nightmare!!
why not just drive onto planks of wood or something? lol
Coz if its really low you will need to drive it onto pieces of wood to even get the jack under there, thats what we do anyway. you can only raise a car by driving onto a plank of wood so much. Or if its not to bad you just get someone to give you a guard lift while you put the hoist arms under
how low are ur hoists arms? mine fit under before a jack does. unless the rails are 2cm off the ground, a plank of wood thats like 6cm is usually plenty to lift the car up to get it on.
this just needed a bit of wood about 3cm thick to get the arms under easily:
its not that low wheels arent bad look alright i spose
Its just a normal Molnar 2 posta. yeah but that doesn't look like it has a low kit on it. its not really the arms that give the trouble its the pads even when wound all the way down still add 2-3cm to the height, then once they are under the car you have to wind them back up so the kit doesn't get crushed on the arms. im not saying driving onto wood doesn't work some/most of the time but Ive had the odd car or 2 come through that is just ridiculous
The hoist we got has a clear floor. You drive the car up on to a couple of blocks then wind the rubber pads all the way up.
If you want Adam you can come put the car on my brothers hoist, take the wheels off and go get some rubber put on them.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
