well, the stag is running like a pig, its been getting worse since just after the stagea meet, but now it feels like its about to stall all the time and i rekon its the coil packs, its always had a miss at idle but now the whole steering wheel wobbles at idle,
question is ive been looking at diffrent coils yellow jackets, jjr and splitfires,
i know the split fires are the best of the bunch but we cant really afford splitfires at the moment (dont hate on us for being poor lol)
but what are the better 2 between yellow jackets and jjr coils,
is there any tests i can do, ive had it on a scanner and didnt really show me anything, not sure if there was any simple test i could do,
any help would be awesome people
Edited by fat-lad
https://www.sau.com.au/forums/topic/276407-coil-packs/
I can only vouch from my experience just fixed my prob last week my prob was the check engine light coming on at start up and then running on 5 cyl i used the guide shown on here to bridge the consult port to get an error code sure enough it came back with the error code for coils bought a set of jjr ones $420 delivered and they work a treat no more prob. My s2 uses r34 type coils as for series 1 i would guess they would be r33 ones but dont qoute me on it. Took me an hour to install them by myself with very limited tools and im a complete noob so its not a hard job im very happy with the quality of jjr coils as are alot of others who bought them as for longevity we will have to see but for the price u can nearly buy 2 sets as a set of spitfires would cost.
Guide to error codes
http://www.skylinesaustralia.com/forums/Re...de-t266512.html
  • Like 1
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4679373
If you are poor or even if you aren't there are a lot of things you can do before splashing out on new coil packs. There are probably thousands of posts on this subject (have a search in the skyline section) but here is something you can do: pull out the coil packs and give them a good clean. have a look for obvious signs of arcing. Use one of the suggestions for insulating them. Sometimes the problem is that they have trouble getting enough oomph to jump a 1.1mm gap that has grown bigger. take out your plugs and if they look new give them a clean (carefully if they are not copper) and gap them to 0.8mm. If they look at all dodgy get a set of Copper plugs NGK BCPR6ES and gap them to 0.8mm. (BCPR6ES-8 are already gapped or BCPR6ES -11 are gapped to 1.1 so gap them down). This may fix your problem. If it doesn't it will have been a worthwhile exercise anyway.
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4679848
plugs are new, and gapped to 0.8, and i did silicon up the coils with some spray they use when making big industrial transformers (friend works for a power company), and there were signs that they were arching out, but hey thinking at work today, we got some polyurathane adhesive maybe ill just paint them with that, just to see if it is the coils or not, but they could still be bad inside,
meh, lol
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4681329
I have a spare perfectly good working coilpack set from my Series 2 Stagea. If interested please PM me. Only reason for the change to Splitfires was wanted larger spark energy running on LPG fuel.
Is it a series 1 or 2 that you have?
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4681598
ian tryed the tape today, didnt work, im now thinking there either dead inside or its another issue, got the codes off it today and its 55 - normal, im started to get real dirty with this stagea now, im gonna pull the injectors off it this week and get them cleaned to see if that cures it. anything else i can try people,
ahhhh also, when i 1st got the car it would stall all the time, i cleaned the throttle body and the aac but found the standard dump valve had a massive air leak so i blocked it off (made a gasket to block it) and thats stopped it stalling, but this miss at idle has always been there since owning the car but its slowly getting worse, could that be an issue? ive also checked for vacum leaks too and couldnt find any.
HELP lol
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4684042
HELP lol
I'm a little confused, are you still trying to see if the coil packs are bad? If so, the quickest way to find out would be start the car and then disconnect one coil pack at a time. If there is no change in engine idle when you disconnect the coil pack, thats your bad one.
Also are these the same coil packs that are on R33 and R32 skylines? If so I should be able to track down a set of used ones for fairly cheap. Anyway let me know.
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4687233
" when i 1st got the car it would stall all the time, i cleaned the throttle body and the aac but found the standard dump valve had a massive air leak so i blocked it off (made a gasket to block it)"
What do you mean by "block it"? Have you rendered the bov totally ineffective? If so try to find another stock bov and give that a try.
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4687313
The stock BOV's have a really piss-poor spring in them and they rely on the vacuum to hold them shut, Luke i've got a Blitz BOV here if you wanted to test it to rule out a faulty factory item. :blink:
Seriously if you've got an idle problem it has to be a dead coil.
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4687880
The factory BOV's are designed to leak slightly back into the intake hence the small hole on the face. This slight leak reduces the likelihood of mild compressor surge. Something most won't experience with stock turbos on RB25DET's or RB26DETT's.
Blocking the small hole may slightly improve response or increase hp by a few kw's but it is really no big deal either way from my experience but if you get compressor surge (with aftermarket turbo) relieving the hole makes the car much better to drive.
Assuming there is no vacuum leak from the hose holding the diaphragm shut then the factory BOV will outperform most aftermarket units as it costs nothing to leave it alone.
https://www.sau.com.au/forums/topic/276407-coil-packs/#findComment-4688173
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
