I thought it may be helpful for some if I put up some pictures that show the easy way to identify a ceramic turbo over a steel wheeled variety. This may be helpful if buying used turbos or if you are unsure if your car has allready been fitted with steel wheel turbo(s). Pull off the front pipe and with an inspection mirror and a torch, and a bit of holding your tounge the right way, you will be able to see it.
Pic 1 - (above) This is a ceramic exhaust turbine - notice the double hex (12 point) end on the turbine.
Pic 2 - (above) This is a steel / inconel exhaust turbine - note the single hex (6 point) end on the turbine
Pic 3 - (above) Also a steel / inconel exhaust turbine - note the triangle end on the turbine
The above is true for Garrett Turbochargers as found on Nissan Skylines RB20, RB25 and RB26 - with the exception of the N1 GTR and Nismo Built cars, all R32, R33 and R34 skylines were fitted with ceramic turbo(s) from factory. Hope this post is helpful!
Edited by Antimatter
easier way is to see if a small magnet sticks to it than remembering those lol
Have you confirmed this works yourself? There was some talk that the alloy used for turbines is not magnetic, but i cant remember if it ever got confirmed or denied.
Inconel wheels dont attract a magnet. I assumed they would till I bought Nismo turbo's. When a magnet did not stick I sh#t myself thinking I had been ripped then I did some research. I can confirm the old turbos on my GTR did have 12 point head on the shaft and the Nismos had 6 point confirming this is a great guide...
Cheers
Lee
Confirmed - magnet trick does NOT work.
As someone else suggested - Inconel (the steel that turbine wheels are made of) is not magnetic. I.e. You will not be able to identify a turbine as steel with a magnet.
Can anyone confirm if the Garrett GT3037R is steel wheeled? I've been looking around for info on this for ages and cannot find my exact turbo on the net. Heres some pics of the turbo. Sorry i dont have any of the rear wheel.
  • 4 years later...
  • 1 year later...
Resurrecting an old thread, but is there anyway to identify the exhaust wheel while turbos fitted to the car?
I've tried using a mirror to see the id plate, but no luck, thought about a boroscope to put up the downpipe but I think the turbo elbos have to sharp a bend.
I don't really want to strip the turbos down, what with all thew work involved. All I can assume is the ceramic wheels are still there so don't want to increase boost.
Thanks in advance. :cheers:
  • 8 months later...
I, too, am going to resurrect an old thread. Same question as ms33, can you check for ceramic/steel exhaust wheel while turbos are mounted? And the photos above are no longer hosted, so if anyone has a picture depicting the 6 vs 12 points he's referring to, that'd be great. Thanks!
Umm....pics 1 and 3 work fine for me. if you can see them then the rest is self explanatory.
You're right. Just checked on my phone. Work computer must've been blocking the host site. Thanks. Cheers!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
