  • Replies 226
Posted Images
Sounds good, Shane. Will get the ball rolling tomorrow at work.
Matt if you see Luke with my old 34 at work, any chance you could ask him if he wants to be involved with the SAU display?
No harm in asking I suppose.
Shane, Am I still showing the R34 inside both days and if so who gets the forms, you or send in direct for the discount off ?
I need to send it in the next few days ??
Send the form in with the full amount and SAU-SA will give you the Discount on the weekend of the show.
Pete, will give it a shot mate. I have to head over his way tomorrow so will see if I can track him down and ask. If you can PM me his surname it will make the job easier, I'll know exactly which section to look for him.
I have filled in my entry form and will fax it off shortly.
well the time depends on what time we have to be there for set up and depending on times of people finishing wk etc?
i'm happy to meet at villies, not sure what time i will be finishing wk, but hopefully early that day (friday)
i believe i'm in the inside event?
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
