um no idea didn't who ever got this off the ground give you forms
Cara initiated it, however the forms were not available for quite some time. No harm in pointing FAQ's to actual solutions rather than wonder in vain as to what was not done.
-D
  • Replies 226
Posted Images
Ben don't be like that i'm trying to be enthused @ least the Current events coordinators wont start an even they cant finish
In this case, they're finishing something they didn't start ;)
I've got copies of the entry form for those who do not have a printer :D you can hit me up Friday night for one at Vilis.
As mentioned, $20 discount for any SAU-SA member ... so its $50. Even better, join SAU-SA now if you're not a member and entering the EHP show and get $20 discount anyway. :D
As Steve said, lets show Adelaide the quality of cars the SAU community can show off.
Once again, you've totally missed my point. Rather than pointing fingers, why cant you just ignore it and move along without taking digs at anyone? Thats 2 posts now where you've felt the need to point out that the previous occupant of your position didn't complete the planning for the event.
Keep it to whats relevant and ignore the past eh?
-D
should be an awesome weekend, get out there and show adelaide who SAU:SA are....
i have it on good authority that there is going to be a locally built 34 GTT there that should put out close to 1200hp at the rear wheels :banana: they just have to finish it in time, you should see the quality of work on this thing.....and the size of the intercooler
So Troy/Anthony/Reuben - any of yous sent off your forms yet? I dont want to enter the Saturday by myself lol
We have 4 cars forms atm but we need more cars for both parts of the show (inside & out ) So please can we have your names if you are going inside or outside on the Sunday
I've done the Autosalon thing, which was a cool experience, but Extreme Horsepower is probably more my scene. I'd be happy enough to enter my car as part of the SAU display inside. If you already have my model covered no problem, I'll just come along as a spectator.
No we would love to have you in the display Download the forms and add the SAU stand to them and send them in .Cheers S
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
