As the post suggests.
ive read all the posts on oils and filters, some say Z145a or equiv, some say other things.
I've just bought a K&N filter off Ebay :laugh: , which was advertised as a z145a equiv.
It FINALLY arrived and the actual part number is HP-2008, and im not sure. i cant find a cross reference for it anywhere and was wondering if anyone had a K&N hanging off thier car?? if so the part number and your thoughts would be great :) as im not gonna pull my car apart before im dead sure.
ive also got a ryco filter sitting in the shed that i bought from autobarn....silly me for thinking they know what theyre talking about on something as simple as an oil filter (considering one of their employees has a R33 GTST sitting out front), its NO where near the right size LOL. but thats my bad.
cross fererence numbers are FRAM PH3682 / DG3682 and PUROLATOR L24457, same here googled both and from what i can see, NON of these numbers fit a skyline, non of the filter manufacturers cover skylines at all, why is this?
Edited by boiracer
https://www.sau.com.au/forums/topic/277055-kn-oil-filter-number/
yeah ive been to the K&N web site....covers pretty well every nissan other than a skyline....you cant even look for one, acording to them they dont exist :P stupid americans.
im sure i read somewhere in a thread here that someone had a K&N one on their car
http://forums.nicoclub.com/zerothread/4094...b25-oil-filters
FINALLLY!!!! i found site confirming that the HP-2008 will fit, but i should read further before jumping around, aparently the 2009 has a bypass, which the 2008 doesnt, so as long as oil stays nice and clean shoudlnt be a problem
Edited by boiracer
HP-2008 IS the correct unit you need. been using them for years on my 25.
Thankyou!!!!!!! really good to finally hear a solid YES for this filter, thanks sooo much man, ive been going nuts trying to figure out if was gonna use it or not :huh:
  • 3 months later...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
