Hi everyone, got a very interesting proposition for all of those R33 Skyline Owners out there with sunroofs who are wanting a 4 Point Half Cage for their R33.
I have spoken to David down at Brown Davis Automotive as I am wanting to purchase a bolt in half cage for my R33 which has a sunroof.
He will be using my car as the dummy and informed me that he can offer me a discount if I have 3 or more done all together.
These 4 point cages (half cage) are full CAMS approved and are powdercoated, have the harnesss bar running across the back and the diagonal bar running from top to bottom.
Price for one:
$1,100 fitted (letting them remove and refit all your trims)
$1,000 fitted if you remove the trims before you take it there
Price for 3-6
$800
Price for 6 or more
$700
Now, these are for R33 GTS-T WITH SUNROOFS! He said he can do the same deal for anyone who doesn't have a sunroof, as long he can use one car to do all the measurements.
Group buy will be running from 1/7/2009 untill the 15/7/2009 so please pm me with some contact info if you are interested.
Payment can be made directly to Brown Davis but I will need a deposit so I can give him the go ahead and produce these half cages.
If your uncertain you can give him a buzz and have a chat to him about the whole group buy.
If your from interstate we can still have these made for you and posted out to you at your expense.
They are located at 47 Holloway Dve, Bayswater, Victoria
http://www.browndavis.com.au/
http://www.rollcage.com.au/rollcage.html
Cheers
Dean
0403059467
Edited by DinoPanta
are the cages ADR approved?
could be interested in one without sunroof for r33.
Brown Davis cages are ADR, and more importantly - VicRoads approved.
Can't go wrong
also interested if it is a bolt on/removable cage. Is it steel or chromoly? brown davis do 2 types....
The FIA has banned CroMo from being used in cages, so if you want it to be legal in the future and what CAMS may implement in light of the FIA banning CroMo, best to stick with cold drawn seamless steel... CDS steel is also safer and cheaper so there's no reason to go CroMo, especially in a road car.
i noticed in the images that there is a 4 point cage in an xr6t that retains its back seat. i know its a sedan with heaps more room but will they be made to accomodate a back seat?
cheers...ben.
Would he want to do an R32 without sunroof? I would be tempted to sell my 7point cusco cage to go down this route...
are they bolt or weld in?
Edited by RB_Ryan
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
