Hi everyone, got a very interesting proposition for all of those R33 Skyline Owners out there with sunroofs who are wanting a 4 Point Half Cage for their R33.
I have spoken to David down at Brown Davis Automotive as I am wanting to purchase a bolt in half cage for my R33 which has a sunroof.
He will be using my car as the dummy and informed me that he can offer me a discount if I have 3 or more done all together.
These 4 point cages (half cage) are full CAMS approved and are powdercoated, have the harnesss bar running across the back and the diagonal bar running from top to bottom.
Price for one:
$1,100 fitted (letting them remove and refit all your trims)
$1,000 fitted if you remove the trims before you take it there
Price for 3-6
$800
Price for 6 or more
$700
Now, these are for R33 GTS-T WITH SUNROOFS! He said he can do the same deal for anyone who doesn't have a sunroof, as long he can use one car to do all the measurements.
Group buy will be running from 1/7/2009 untill the 15/7/2009 so please pm me with some contact info if you are interested.
Payment can be made directly to Brown Davis but I will need a deposit so I can give him the go ahead and produce these half cages.
If your uncertain you can give him a buzz and have a chat to him about the whole group buy.
If your from interstate we can still have these made for you and posted out to you at your expense.
They are located at 47 Holloway Dve, Bayswater, Victoria
http://www.browndavis.com.au/
http://www.rollcage.com.au/rollcage.html
Cheers
Dean
0403059467
Edited by DinoPanta
are the cages ADR approved?
could be interested in one without sunroof for r33.
Brown Davis cages are ADR, and more importantly - VicRoads approved.
Can't go wrong
also interested if it is a bolt on/removable cage. Is it steel or chromoly? brown davis do 2 types....
The FIA has banned CroMo from being used in cages, so if you want it to be legal in the future and what CAMS may implement in light of the FIA banning CroMo, best to stick with cold drawn seamless steel... CDS steel is also safer and cheaper so there's no reason to go CroMo, especially in a road car.
i noticed in the images that there is a 4 point cage in an xr6t that retains its back seat. i know its a sedan with heaps more room but will they be made to accomodate a back seat?
cheers...ben.
Would he want to do an R32 without sunroof? I would be tempted to sell my 7point cusco cage to go down this route...
are they bolt or weld in?
Edited by RB_Ryan
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
