  • Replies 477
can anyone get these made up?. i would love that set up on my 33gtr, or is anyone selling one?. bernie
Im having one made up along with a slightly different design.
Can get more made but shipping would be a pain/expense
I got a price on them which I think were 400-500 for fronts alone.
The local 'race brakes' are only 150 for fronts, my mate who was doing 1:07 at wakefield in a stock r32gtr did back2back testing with a no. of pads including some jap brands and bendix ultimate, in terms of braking power and wear the race brakes came out on top.
If anyone is interested I can find his email and post it here?
Bernie - that is a custom job BUT the apexi n1 system is the same with 2 x 3inch pipes and straight off the shelf
cheers marko, we dont really have exhaust people here that can mandrel bend and supply silencers of that qaulity, what would one cost made in oz and shipped to me..lol any takers.lol
my hks preist would probably give me 400 uk back to spend
Edited by rockabilly
To get a full system done in 4inch including front pipes is approx 4k aud, now to run 2 x 3 inch pipes I'd assume would be more than as it is essentially 2 exhaust systems + shipping which I would think is 500 aud.
Bernie, what's the latest with your donk :merli: nothing worse than an engine failure, other than a funeral
Try Racer Industries in Bris. Mine cost $276/pair. The 4-500 sounds like some more serious Mu pads.
Edited by Scooby
quick update:
my new brake setup feels phenominal...the combination of refaced factory rotors, 'race brakes' pads & motul factory line brake fluid gives me all the confidence i need, dont know how long they would last on the track though with over 400awkw :D thats ok, i'll just turn down the wick on track days (if/when i get out there)
for the 1st time, i activated my abs with fark all pressure on the pedal haha
i have noticed that my pedal sinks lower to the floor though than previously, is there an adjustment to bring in the contact point a bit earlier?
cost. if i upgrade my braking system though, i will get k-sports all around which will set me back about 4k.
refaced discs = $100
f&r pads = $300
brake fluid = $70
i also dont think i need huge brakes for the street - the likes of duncan who race in production advises that the factory gtr brakes are quite good when setup right.
i know with the power i have i should get bigger brakes - for now though, im wrapped & dont see the requirement :D
come to think of it - if i ever break this box like i did in my other gtr, i'd probably just get another gtr box exchange unit...these days u can get them for under $1000.
what is the cost to get an os gearset fitted in a box (i'd do the r&r myself)?
well its $ 2,848.10 + shipping for the 5 gear kit from RHDjapan at the moment, plus what ever it costs to have it fitted into the box/replace synchros/bearings (i remember something about the R32 box needing some R33 parts as they were stronger/better?)
Well, if you break one and spend another $1000 on another stock unit it makes sense at least to me to get the upgraded box cause the next stock one will just break again. That's my thinking anyway
when I enquired for my box I think it was something like 1500?
Then of course a donor box (350 or so for a worn out one) and a gearset (price of course depends on how wild you go)
well if it was going to cost me 3kish i'd definitely take that path. that is very cheap!
i should speak to terry @ award diff for a price on fitting the gearset.
i always thought it was up around the 7k mark?
apparently the input shaft also needs to be upgraded as well on the r32.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
