Hi all,
I have some HID kits left over from a group buy that need to go.
H1 6000k (R33 GTST)
H1 8000k (R33 GTST)
H4 6000k
H4 4300k
HB3 8000k
(IS200 low and high beam)
HB4 8000k
H11 4300k
D2S 6000k
All kits are $180 Delivered. $19 cheaper than GB price.
I also have a kit that i made up from spare bulbs and ballasts: H4 4300k $100 (one ballast was used for a month, still in perfect working order)
CHEERS
https://www.sau.com.au/forums/topic/277558-left-over-hid-kits/
  • Replies 46
HID works best with projector lights as the beam pattern is focused.
HID works with all bulb types.
Are you sure your car has H4?
I thought 32s had either H1 or H3?
i have N1 headlights which uses h4, previously had projector ones which had h3c
which brand are these???
Mostly VEGA DIAMOND, some BOSCH.
OK no problem. Just to let you know these are single beam kits and do not do high beam.
If there is anyone who has put HIDd into the N1 headlights please shed some light as to what kit you have out in?
hey mate, do the 6000k H1 also direct fit for 34 gtt? or they use different harness?
edit: also are these the bosch/philips ones?
Edited by .:: GimpS-R34 ::.
hey mate im keen to buy a set
i have a 34gtt
and it doesnt have xeon lights anymore coz they got taken out when they complied it i think
do u have any kits for me?
and how much extra for some led parkers?
thanks heaps mate
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
