hey mate im keen to buy a set
i have a 34gtt
and it doesnt have xeon lights anymore coz they got taken out when they complied it i think
do u have any kits for me?
and how much extra for some led parkers?
thanks heaps mate
Exactly what I was going to write :thumbsup: +1 here
Cheers
  • Replies 46
Need these gone.
Sorry for the late reply mate. yeah the factory Xenon's were replaced with H1 bulbs. Can you pm me which kit and cost and ill grab your details for payment.
Cheers
As i only have 1 H4 6000k left yes i can do that for you :P
H4 HELLIGKEIT 4300k (light output like 5000k)
H4 VEGA 4300k
9006 VEGA 8000k
9005 VEGA 8000k
D2S 6000k
Still available
PM Sent.
one final question. how hard is this to wire up. i'v never fitted one up to a 180sx before.
also where you located. if close by i'll just pick up and save you haveing to deliver. maybe save me some $$$ on postage too.
Edited by DV5180
Very straight forward. These are plug and play units so no splicing or wiring.
The only hard bits are making the 25mm hole in the dust cover and finding a place for hiding the ballasts :P
Remove dust cover
Remove halogen bulb
Drill 25mm hole in dust cover
Put in HID bulb
Connect HID bulb to ballast
Connect HID bulb wires to stock headlight wires (H4 stock headlight plugs has 3 prong, the HID has two, just find the - and + buy testing)
Then disconnect them as you will need to feed all the wires through the dust cover
The grommet on the HID bulb wires fills the hole in the dust cover so the elements cannot get in
Thats pretty much it.
Will take around 20mins-30mins to install.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
