hey mate im keen to buy a set
i have a 34gtt
and it doesnt have xeon lights anymore coz they got taken out when they complied it i think
do u have any kits for me?
and how much extra for some led parkers?
thanks heaps mate
Exactly what I was going to write :thumbsup: +1 here
Cheers
  • Replies 46
Need these gone.
Sorry for the late reply mate. yeah the factory Xenon's were replaced with H1 bulbs. Can you pm me which kit and cost and ill grab your details for payment.
Cheers
As i only have 1 H4 6000k left yes i can do that for you :P
H4 HELLIGKEIT 4300k (light output like 5000k)
H4 VEGA 4300k
9006 VEGA 8000k
9005 VEGA 8000k
D2S 6000k
Still available
PM Sent.
one final question. how hard is this to wire up. i'v never fitted one up to a 180sx before.
also where you located. if close by i'll just pick up and save you haveing to deliver. maybe save me some $$$ on postage too.
Edited by DV5180
Very straight forward. These are plug and play units so no splicing or wiring.
The only hard bits are making the 25mm hole in the dust cover and finding a place for hiding the ballasts :P
Remove dust cover
Remove halogen bulb
Drill 25mm hole in dust cover
Put in HID bulb
Connect HID bulb to ballast
Connect HID bulb wires to stock headlight wires (H4 stock headlight plugs has 3 prong, the HID has two, just find the - and + buy testing)
Then disconnect them as you will need to feed all the wires through the dust cover
The grommet on the HID bulb wires fills the hole in the dust cover so the elements cannot get in
Thats pretty much it.
Will take around 20mins-30mins to install.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
