Hiya all,
about 5 months ago I bought my first stagea. it's a 2001 M35 300RX (VQ30DD) with 70,000Km down, as I understand it you still can't get this model through compliance in Australia, too bad really it makes a great middle ground between the 250RS and the VQ25 turbo model.
I'm a design engineer by trade based in Auckland so I'm the sort of guy who likes to pull things appart and fix my own problems before I take anything to a mechanic.
So far I've found one or two issues with my wagon and managed to fix them in the shed. I'm keen on learning more about these wagons and sharing my own experiences of living with and maintaining my ride.
Edited by chad bob
https://www.sau.com.au/forums/topic/277904-my-first-stagea/
It's my long lost twin!!!!!
I'm the black sheep of the family, I've got the 250t RS :)
Give me the option between the 3L and the 2.5L turbo and I'll take the turbo everytime, can't wait to high-flow!!
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4697742
I'm the black sheep of the family, I've got the 250t RS :P
Heh, yours does look like the evil twin with that body kit.
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4697821
Are you jealous Cam? Aero kit rules.
Chad, I bet its cheaper to run than our turbos.
It might be.
-On long cruises with only a couple of hills and me in 'cruise mode' it gets 8-9L/100km
-This weekend I drove up north, I was in 'lets just f***ing get there' mode and there were a lot of slow buggers around on steep windy roads so a lot of foot flat up hill passing (these VQ30's actually get up and go rather nicely) fuel usage = 12-13L/100km
-Around town commuting to work etc I get 10-11L/100km
Compared to a stock 250TRS the seat of the pants meter tells me that the VQ30DD isn't really that far behind on the performance scale they get to 100KPH in about 7.5Seconds, what does the VQ25DET do the ton in?
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698038
I timed mine with the I phone :P
6.5 sec is rather impressive for a big wagon,
my major gripe with the VQ30DD is that it has little torque below 3000RPM, the VVT kicks things up at 3000RPm and then you start going, but I found that the VQ25DET has balls from early in the rev range, big bonus.
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698055
+1 on aero kits ruling. i think he is jealous :P
Hahaha! No, not jealous guys... Just thought that Stephen might bite first...
On a good day - 6 flat.
On a not-so-good day - nearly 7.
I really have to get my intake & dump sorted
Edited by iamhe77
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698064
I think VQ30 and VQ35's are only differentiated by the Direct Injection heads on the VQ30 and the extra stroke length of the VQ35. The bore dimensions are the same on both motors.
I think the VQ25 has a smaller bore and stroke than the larger motors.
In the future I want to put a VQ35 intake on my motor and also some aftermarket VQ35 headers.
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698084
i saw your post about the Di motors and lacking performance. i should suggest something in that thread. i had a thought!
Sounds good, write it up in my Di motor thread, I'd be glad for any thoughts.
Nope.
VQ25 - Bore 85mm Stroke 73.3mm
VQ30 - Bore 93mm Stroke 73.3mm
VQ35 - Bore 95.5mm Stroke 81.4mm
Crap! I thought that the 30 and 35 had the same bore with a longer stroke, ah well not that it matters.
Edited by chad bob
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698109
the VQ25DET starts building boost at around 2000rpm (well thats when its noticeable - ie. when you feel it) and from there it accelerates pretty rapidly. The revs would also build up slightly quicker at that point. I like to describe the power delivery of the VQ25DET as "ferocious" although that may be overstating it just a little ;)
Even though there is a small difference in reported power between the two engines (191kw vs 206? kw) the difference in peak torque is much greater (325N-m vs 407N-m). Interestingly the VQ30DD almost has as much power and torque as the RB25DET NEO - just shows you how far technology has progressed in just a few years.
https://www.sau.com.au/forums/topic/277904-my-first-stagea/#findComment-4698185
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
