First of all I was saying. If I start my car an put it in drive an slide it cross to tiptronic mode it would show 3rd gear but I have even move the car yet. I though it would suppose to be in 1st gear while stationary without moving the car. I need some direct injectors. Any body possible know where I could find it for the vq25dd v35 250gt skyline 2003. I have one leak direct injecting cause my car to run rich
Honestly, I don't know why, but you don't seem to be interested in listening to the advice you've been given in this forum. You're obviously well out of your depth. Your lack of gratitude for those that have helped, and inability to string a legible sentence together doesn't help.
Good luck. You're going to need a lot of it.
I have tried every diagnostic advice from many of you which cause ms spend alot of money. Seems that none of the advice is working. Yall have access to these cars, parts and other items that can assisted yall with ur car problems. These vq25dd are not familiar to were am live an for every advice I get possible it makes me spend money an nothing works. All am asking is a website that sell injectors for these cause because there is one cylinder that making the spark plug have a dry foul on it an that cylinder smell like fuel
Were I live everything GA a be order an shipped here. Parts are not available for these vq25dd an yall advice made me spend more money an these people who diagnosis the car stating no codes at all. About this one cylinder that causing a rich running engine misfire. It just one cylinder which I meet a bit of fuel left inside so I was suspecting leaking fuel injector.
So it's all our fault then? Where do you live? You haven't told us, and I didn't see anything in your profile.
I think you've been advised to get your injectors tested multiple times, but I don't think you've taken this advice. Unless you do, I'll bet this will end up in tears.
Edited by Spong
But this is a DD engine.. so an injector that isn't closing fully isn't just going to have a 'run rich' issues like a non-direct injected engine.. you are going to end up with combustion pressures forcing their way through the leaking injector, back into the fuel rail and causing major issues overall, not just a fouled spark plug and poor economy.
I live in the Bahamas. I change alot of plugs an everytime I change it. I get a misfire an its the same cylinder that causing it. An not it is the coils causing it
Why aren't the coils causing it?
Edited by Ben C34
It only shows the highest gear you are allowing your gearbox to reach. The actual gear is not related to the display
They brand new Nissan coils from Nissan Japan. OEM
So?
Have you tried swapping coils to see if the problem cylinder moves?
Who says your wiring is all good?
I would be checking that before messing with the injectors. But it's your call. Up until now this site has wasted your money.
Edited by Ben C34
Everything yall saying I have test. I have already swap coils an plugs an problem still exist. I meet a little bit of fuel in that cylinder that causing the misfire. Then other five dry. Time to swap injectors to see if the problem persist in another cylinder
You can order a minimum of five, and still be cheaper than factory.
Your looking at 330AUD each for genuine ones...
They might not be of the same quality however.
Up to you to take the choice.
What plugs are you running, obviously not the correct quad earth's, they are impossible to find.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
