Decision time - 3 choices only please
40 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I think I've picked the 'most common' from the previous thread...
Please select only THREE - These are your three top preferences.
Selecting 3 will simply make it much easier to get the "top" games so we can get moving on it all :D
And also a voice setup... i have a private Vent server we can use for some nights - it is free but compressed so the sound it a little crap (very large server)...
Im thinking of buying my own and hosting so that could change
Any other info (like a specific server or something you prefer etc etc for some games).
I'm thinking mid/late week wed/thur.
Looking good so far - the interest thread had some massive interest
https://www.sau.com.au/forums/topic/278614-sau-gaming-nights-game-decision/
I have voted, but for us strategy freaks, I would've liked to have seen Company of Heroes up there, I know me and another couple of guys have it...
It would only be fair considering that it is simply brilliant and genre jolting game...
Also, there were more than a few hands up for BF2...
Edited by Marco-R34GTT
im easy mate - if i missed a game or two sorry - i skimmed it and posted the ones i could see that were most common :)
im for any game, half of the poll ones i dont have but they are fairly cheap so ill just buy em!
we can always organise other games, change and so on once we actually get something regular going on which is the first part i reckon
Well i'm up for some CS:S and TF2 action...
I did have COD 4 and COD 5 - lent them to a friend and he's gone AWOL - damn....
well there's always ozcdkeys to get new keys for COD 4 & 5 - can always get a pirated copy from friends but just need to buy legit cd-keys to play online
I'd love to play C&C 3 - the single player is truly awesome and is the result of them paring back all the annoying and useless things about C&C games and making it into the ultimate (apart from Total Annhiliation) RTS experience.
I'd go for a game of CS too, but I can't get Steam to work on either of my computers.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
