http://onyxsyndicate.com/newman/e30gtr/e30gtr_88.html
I spent a few hours last night buttoning up the AN Plumbing on the car. DETAILS DETAILS DETAILS!
Oil feed and cooling lines:
The coolant line attaches to a nipple on the water outlet. Instead of going through the hassle of welding on an AN bung, I simply used a hose end cover. It's a little corny, but it looks pretty good.
Ran the lines to the Aeromotive FPR. I still need to put a plug in the other port. I also cut off the vac port for the old charcoal canister and plugged it, then added another clamp for the fuel feed line at the back of the plenum. You can see what's missing if you compare it to THIS pic.
Another shot of the FPR
I wish you could see the brackets that I made for the brake booster line. I made 3 stainless L brackets and used them to mount line clamps to. They came out really nice and hold the vacuum line very straight. I am planning on mounting the check valve in between the two closest to the camera. Again I used hose finishers to clean up the look.
Another shot of the FPR showing the cable clamps holding the return line.
Another shot of the brake booster vacuum line. There's a clamp that's hard to see mounted to the head lifting bolts. (The other two are off the plenum and intake studs)
Shot of the drain and coolant line. I made both the drain flange and the block flange, wish I had a pic of them off the car, they came out awesome. I still have to do something with this coolant line.
Here's a shot of the block flange on the car.
I also took the rotor hats off the car so I can get them anodized.
  • Replies 74
Posted Images
The level of detail gets better as the build goes on, well done :)
Only thing I can think of is maybe some flame proof wrap for the turbo oil and water lines, it will get damn hot in there and wouldnt want them melting
Amazing! Im sure you will as it seems you miss nothing. But im assuming your going to clamp that hose on the right away somewhere? Itl rub through in a matter of weeks sitting on that seam in the bodywork! (Pic of lines under Turbo compressor by the "M24" casting)
Yeah, that's why I said:
"I still have to do something with this coolant line."
In the pic's caption.
I'll probably butterfly it to the drain line and glue some vacuum tubing to the seam.
  • 3 weeks later...
Shot of the intercooler and radiator installed (temporarily):
Then I started installing the window gaskets and some of the trim. The trim is actually blacked out with vinyl, which is a pretty popular way to do it. It looks really good:
Lastly, I made and installed some AN lines to be used with my PCV vacuum setup. That unaatached line will go to a catch can, then into the exhaust evacuator.
Got my coolant pipes coated in brushed aluminum PC and my bumper brackets in black.
I put a bead on the pipes with these vice grips I modified. Got the idea from Dan (JUICEDZ4)... In fact that's actually his pic... but mine are nearly identical.
Check out his AWESOME cavalier build here. I know it's a Cavalier, but check it out, it's unreal.
I bought some cheap summit racing window cranks and machined an adapter to run them on my gutter power window housings.
More shots of the outside. It's even more yellow than it appears in photos. Very odd color indeed. 4/6 windows are in. As is BLACKED OUT TRIM
PHAT AZZ... (the apron has some black on it at a weird angle so it looks crooked, but it all gets covered by the rear valence) Also got the trunk latch and tails installed. Looks like a fox notch hahah.
A shot of the CHROME BILLET WINDOW CRANK$$$ installed (23 bucks from summit)
And FINALLY got a set of these. SOOOO much better than a crescent wrench with electrical tape on it.
Also summit racing must hate that I keep adding shit to this order over and over. Check out all those different ship dates, all on 11.95 handling. :D
Nah, they probably love me...
Look at all this other shit I ordered.
Added a line clamp for the oil feed line and installed the EGT fitting into the manifold. The schedule 10 should be thick enough to not weld a bung on there, time will tell.
Powdercoated coolant pipes installed, you can also see where I am going to weld the BOV flange on.
Steph's baffled catch can installed. You can kinda see how the lines route now. One more line comes from the bottom of the catch can to the exhaust scavenger, which will be after the WG return and flex section.
A shot of the line feeding the catch can and also notice the brake booster check valve installed in-line. Again, trying to keep it ultra clean looking, this time line mounts to firewall.
Rear PACKAGE TRAY dyed black and installed. Instead of factory mounting I simply chose to use 2 stainless self-tapping screws in the front and clips in the back.
Lastly for tonight: Back Glass.
Just scooped up this, and the interface to communicate directly with AEM:
http://www.race-technology.com/dash2_2_31.html
And a fuel sender from summit. (Oh yeah and a 2.75 cent fitting that's backordered until october, LOL)
First thing I did was install the fuel tank level sending unit. Pretty straightforward.
Radiator fan installed:
Wideband bung welded on:
Spiffy downpipe bracing to motor:
Lastly, and most awesomely, I made this closeoff out of laser cut aluminum and pre-preg carbon fiber.
Large work was conducted above a machine, turbine very good! Successes in future!
To many on Rb26 liked to put here such turbines!
1000hp!!!!
HKS
This is probably the best comment I have ever received in any of my build threads.
Edited by ctnewman
glad I'm not the only one with tape on my crescents haha
So when do we get to see the flares?
flares, even the rears can't go on til sideskirts are on
sideskirts can't go in til fenders go on
fenders won't go on til it's tunning, probably, so you gotta wait a bit...
Wow....I thought an E36 with an 1JZ would be crazy, but this Bimmer made me speechless. Really good and detailed job mate. Quiet cool to see that you left the steering wheel on the left side :ninja: It's really going to be a trackday monster.
Good luck in the future :P
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
