Hey
Just fitted a JJR Stealth Front Mount Intercooler. I haven't upped the boost or anything since I don't have a boost controller.
Problem is that everytime it hits the higher boost under hard acceleration these pipes blow out because of the high pressure.
When fitting this intercooler did anyone upgrade the clamps on that piping? Or replace those metal pipes with silicone ones?
I believe they are coming off because the pipes don't directly line up without slightly forcing them to. And there is no leeway in the piping being metal so all of the stress from the pressure is being put on the clamps.
Better clamps might just do but if I could replace those pipes with silicone ones it would be much better I reckon.
I couldn't find any direct replacement pipes in silicone. Does anyone know where I can get some? Or do I need to cut my own?
Cheers.
I fit one of these last week to an R33 and they aren't a direct fit. I spoke with JJ about it and they said they fit more to 34's than 33's and don't have a problem. The intercooler sits 1 inch over towards the drivers side so what you need to do is cut the mount on the top and weld it back on 1 inch over and then cut 1 inch out of the longer pipe before the first bend. This not only centralises the intercooler but it also makes the shorter pipe better able to go directly into the factory one in the engine bay. Previously it went in at an angle. After moving the intercooler across, it went in no problems.
As stated above, also make sure all the pipes are pushed into the factory rubber bends enough. If they aren't pushed in enough, they will continue to blow out.
Ah that explains everything. I was scratching my head wondering how the hell they could have designed this system as a bolt on when half of the mounts don't even line up to the car. Like why design a system for a car to not line up with that car if you know what I mean? Lol.
But yeah we already did all of that. The top mount is cable tied just to the right of the central pillar on the front so the bottom mounts line up with the holes on the chassis. That way also the pipes can actually connect properly. The mounting of the actual intercooler was done correctly.
But I might be able to tighten up the clamps better. So I will give that a try.
If I can find some silicon pipes that replace those black metal ones then I would upgrade them regardless.
Which one's are blowing off exactly?
The metal black one from the turbo or the longer one into the engine?
Or the 90 degree rubber bend on the end of those pipes?
Or the new pipes that came with the kit?
If you didn't cut 1 inch out of the long pipe then it won't fit. I assume you did as it doesn't go together without doing so.
Hmm thats odd... im doing 240kws with the JJ cooler runing at 16-17psi and no problems there..... You need to upgrade you clamps! get the NORMA ones..... thats what im using... i full give it to hard and never pops of!
Yeah looks like new clamps and ultra tightening them is the way to go.
I can't remember what size the clamps were. Anyone know? I don't have a decent measuring device. Lol
Might just grab some JJR ones since they are fairly cheap and look like the ones that came with the intercooler kit. And those ones are holding up sweet.
I also had this problem so i tightened the clamps like said before with a ratchet and also welded a lip to the cooler pipes and bolted somewhere to the body.
dont tighten the clamps too tight - they will chew out the side of the hose.
A decent clamp, with a decent lip and you wont have a problem
The pipe lip/bump is as important as the clamp if not more-so, i ran stock RB25 clamps over 25psi with lipped piping.
First time it was the smaller one going to the turbo.
Second time it was the larger one and it blew off the elbow.
They are all original pipes with original clamps. The aftermarket pipes that came with the kit are holding up well so far.
When you say "lip" you mean make a lip on the pipes that are blowing off where it joins the the joiners?
What boost are you running? If the stock hoses are blowing off, then there is an issue.
I am not sure. Don't have a gauge or controller. But it doesn't seem to be overboosting or anything.
I really should get a gauge.
One trick I used to stop clamps blowing off my I/C SS Pipes was to use decent clamps but also get a steel tang srew driver and put the sharp end inside the pipe about 5mm and support it on something maleable and give it a hit which would put a neat protrusion into where the rubber hose slides over but let the clamp grip it when tightened.
Not sure if that make sense but you get the idea.
Yeah I will give that a go. I will be fiddling with these pipes all Saturday that is for sure.
I always put some tac welding on four points around the pipe once it does not have that sealing lip and it never comes out. Next thing I also do is use hair spray on the pipe right before putting on the hose Once that stuff gets on it won't come off and seals well as well.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
