Hey
Just fitted a JJR Stealth Front Mount Intercooler. I haven't upped the boost or anything since I don't have a boost controller.
Problem is that everytime it hits the higher boost under hard acceleration these pipes blow out because of the high pressure.
When fitting this intercooler did anyone upgrade the clamps on that piping? Or replace those metal pipes with silicone ones?
I believe they are coming off because the pipes don't directly line up without slightly forcing them to. And there is no leeway in the piping being metal so all of the stress from the pressure is being put on the clamps.
Better clamps might just do but if I could replace those pipes with silicone ones it would be much better I reckon.
I couldn't find any direct replacement pipes in silicone. Does anyone know where I can get some? Or do I need to cut my own?
Cheers.
I fit one of these last week to an R33 and they aren't a direct fit. I spoke with JJ about it and they said they fit more to 34's than 33's and don't have a problem. The intercooler sits 1 inch over towards the drivers side so what you need to do is cut the mount on the top and weld it back on 1 inch over and then cut 1 inch out of the longer pipe before the first bend. This not only centralises the intercooler but it also makes the shorter pipe better able to go directly into the factory one in the engine bay. Previously it went in at an angle. After moving the intercooler across, it went in no problems.
As stated above, also make sure all the pipes are pushed into the factory rubber bends enough. If they aren't pushed in enough, they will continue to blow out.
Ah that explains everything. I was scratching my head wondering how the hell they could have designed this system as a bolt on when half of the mounts don't even line up to the car. Like why design a system for a car to not line up with that car if you know what I mean? Lol.
But yeah we already did all of that. The top mount is cable tied just to the right of the central pillar on the front so the bottom mounts line up with the holes on the chassis. That way also the pipes can actually connect properly. The mounting of the actual intercooler was done correctly.
But I might be able to tighten up the clamps better. So I will give that a try.
If I can find some silicon pipes that replace those black metal ones then I would upgrade them regardless.
Which one's are blowing off exactly?
The metal black one from the turbo or the longer one into the engine?
Or the 90 degree rubber bend on the end of those pipes?
Or the new pipes that came with the kit?
If you didn't cut 1 inch out of the long pipe then it won't fit. I assume you did as it doesn't go together without doing so.
Hmm thats odd... im doing 240kws with the JJ cooler runing at 16-17psi and no problems there..... You need to upgrade you clamps! get the NORMA ones..... thats what im using... i full give it to hard and never pops of!
Yeah looks like new clamps and ultra tightening them is the way to go.
I can't remember what size the clamps were. Anyone know? I don't have a decent measuring device. Lol
Might just grab some JJR ones since they are fairly cheap and look like the ones that came with the intercooler kit. And those ones are holding up sweet.
I also had this problem so i tightened the clamps like said before with a ratchet and also welded a lip to the cooler pipes and bolted somewhere to the body.
dont tighten the clamps too tight - they will chew out the side of the hose.
A decent clamp, with a decent lip and you wont have a problem
The pipe lip/bump is as important as the clamp if not more-so, i ran stock RB25 clamps over 25psi with lipped piping.
First time it was the smaller one going to the turbo.
Second time it was the larger one and it blew off the elbow.
They are all original pipes with original clamps. The aftermarket pipes that came with the kit are holding up well so far.
When you say "lip" you mean make a lip on the pipes that are blowing off where it joins the the joiners?
What boost are you running? If the stock hoses are blowing off, then there is an issue.
I am not sure. Don't have a gauge or controller. But it doesn't seem to be overboosting or anything.
I really should get a gauge.
One trick I used to stop clamps blowing off my I/C SS Pipes was to use decent clamps but also get a steel tang srew driver and put the sharp end inside the pipe about 5mm and support it on something maleable and give it a hit which would put a neat protrusion into where the rubber hose slides over but let the clamp grip it when tightened.
Not sure if that make sense but you get the idea.
Yeah I will give that a go. I will be fiddling with these pipes all Saturday that is for sure.
I always put some tac welding on four points around the pipe once it does not have that sealing lip and it never comes out. Next thing I also do is use hair spray on the pipe right before putting on the hose Once that stuff gets on it won't come off and seals well as well.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
