R34 Cop CAR!!!!
Guest Sphyncter
Originally posted by predator666
what? like a AVC-R? S-AFC? and maybe a turbo timer or two.. and maybe A SATELITTE TV SYSTEM?!! damn, hey wait a sec they're on there as stock..
i said like you see in the commos and falcons, pay attention! the cop shit is nothing like what you see in a gtr.
  • Replies 40
Guest Sphyncter
if you read the original post you will see i said i was in an xf ute and in no shape for dragging. i never said i was gonna drag anything, all i said i was that i was trying to catch up to him to have another look. nothing was said about dragging except that i wasnt going to. besides the fact that it wasnt said, you were concentrating on the wrong part of the story. the point being there was an r34 gtr cop car! so the fact that i own a silvia is completely irrelevant seeing as it was never even mentioned. nice attention to detail!
p.s. front bar looks nice
Guest Sphyncter
Originally posted by MzDfectd
woahhh down boys
relax a lil the guy was only trying to give u all some helpful info
no need to give him shit
thats not wat this club is about
thank u for the info dude
much appreciated
thankyou very much. you try to help some people.... i cant believe you people would get caught up in meaningless shit like what type of car i drive when i see a gtr. for christ sake, it was a warning. and as adzmax said, people would gauge their car against it anyway so hating on me for driving a silvia gets us nowhere.
no guys sorry i didnt see the plates. ill report back if i see it again. im sure someone will see it at some stage. next time ill know when its coming and will write it down.
there's no point getting worked up over it, its not gonna be used for traffic duties... its owned by the SOG (the guys who have the power to say to ordinary cops "*** orf" and they have to go "yes sir"). I just confirmed with my mate, the car has had work done and has been deployed. ATM they're usuing ordinary gear in the car (same shit u find in undercover cop cars) but they're working on a touchscreen alternative with the gear in the boot, so no one can tell at all (cept for an antenna attached tot he boot), hopefully I'll get to see the car sumtime soon when my mate gets patrol duty or sumfin.
Originally posted by DJ_L3ThAL
but they got that yellow pontiac for city driving didnt they!??!?!!?!
$250k i think it was, based at cartlon station.. such a waste
250k?? for a pontiac??for city driving??? perhaps a few laps of Chapel?? ;)
i cannot see how this could be......but i do know they have a monaro given to them at no cost and it is yellow.
R34 cop car! hella cool. Munky invite him on a cruise.... INVITE!!!! ;)
hahah, NOS in the supra. Someone is def watching too much fast and furious.
i've seen the Yellow GTO a bit, is it GTO or top spec GTS? Seen it twice on St.Kilda road, i think one time it had pulled somone over? can't remember.
unmarked R34 GTR cop car on a SAU cruise? i reckon that would be tops.
Is it Vspec? Vspec II?
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
