R34 Cop CAR!!!!
Guest Sphyncter
Originally posted by predator666
what? like a AVC-R? S-AFC? and maybe a turbo timer or two.. and maybe A SATELITTE TV SYSTEM?!! damn, hey wait a sec they're on there as stock..
i said like you see in the commos and falcons, pay attention! the cop shit is nothing like what you see in a gtr.
  • Replies 40
Guest Sphyncter
if you read the original post you will see i said i was in an xf ute and in no shape for dragging. i never said i was gonna drag anything, all i said i was that i was trying to catch up to him to have another look. nothing was said about dragging except that i wasnt going to. besides the fact that it wasnt said, you were concentrating on the wrong part of the story. the point being there was an r34 gtr cop car! so the fact that i own a silvia is completely irrelevant seeing as it was never even mentioned. nice attention to detail!
p.s. front bar looks nice
Guest Sphyncter
Originally posted by MzDfectd
woahhh down boys
relax a lil the guy was only trying to give u all some helpful info
no need to give him shit
thats not wat this club is about
thank u for the info dude
much appreciated
thankyou very much. you try to help some people.... i cant believe you people would get caught up in meaningless shit like what type of car i drive when i see a gtr. for christ sake, it was a warning. and as adzmax said, people would gauge their car against it anyway so hating on me for driving a silvia gets us nowhere.
no guys sorry i didnt see the plates. ill report back if i see it again. im sure someone will see it at some stage. next time ill know when its coming and will write it down.
there's no point getting worked up over it, its not gonna be used for traffic duties... its owned by the SOG (the guys who have the power to say to ordinary cops "*** orf" and they have to go "yes sir"). I just confirmed with my mate, the car has had work done and has been deployed. ATM they're usuing ordinary gear in the car (same shit u find in undercover cop cars) but they're working on a touchscreen alternative with the gear in the boot, so no one can tell at all (cept for an antenna attached tot he boot), hopefully I'll get to see the car sumtime soon when my mate gets patrol duty or sumfin.
Originally posted by DJ_L3ThAL
but they got that yellow pontiac for city driving didnt they!??!?!!?!
$250k i think it was, based at cartlon station.. such a waste
250k?? for a pontiac??for city driving??? perhaps a few laps of Chapel?? ;)
i cannot see how this could be......but i do know they have a monaro given to them at no cost and it is yellow.
R34 cop car! hella cool. Munky invite him on a cruise.... INVITE!!!! ;)
hahah, NOS in the supra. Someone is def watching too much fast and furious.
i've seen the Yellow GTO a bit, is it GTO or top spec GTS? Seen it twice on St.Kilda road, i think one time it had pulled somone over? can't remember.
unmarked R34 GTR cop car on a SAU cruise? i reckon that would be tops.
Is it Vspec? Vspec II?
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
