Ahh well that screws that idea then ;)
yeah, the standard R34 GTR front diffs from Nissan are $2300, dont know if there is any difference between the standard and the Nur spec will take $1500 for it as its brand new though
should have someone interested in it soon though
  • Replies 83
Posted Images
  • 5 weeks later...
if you are interested speak to rhemac in sa. They are de stroking rb30 cranks to fit rb26 blocks.
my rb26 is now 2.935.33cc. its not tuned yet so i cant tell you how it feels on the street but i can keep you posted. hopefully around 4 weeks.
Not much of a de stroke if its 2935cc, are you sure thats right and you sure it fits?
Rob
seriously though its for the sports sedan. I have to run a factory block but I am not stuck to factory capacity :laugh:
btw how is your car going....you need to bring it up to our show and shine...we need a great collection of 32 race cars
Rob
this is calculated on virtual engine calculator. bore= 86.5 stroke = 83.25. we've had custom pistons made from JE to achieve this.
Sounds great if it works but just so you know 86.5mm is normal for a new RB piston and the design of the custom pistons (other than the bore which at the size you have won't give big cc gains) has nothing to do with capacity.
The cc's your talking about have come about from the stroke, not the custom pistons you've had made.
What rods did you use?
Rob
I think when momentum gtr is saying custom pistons made for the 2.9, he means; custom in the comp height (distance from gudgeon centre line to crown of the piston). That way the extra stroke to increase the capacity can be taken up by shortening the comp height from std.
Yes this does work, and can/has been done. i developed it for my car. I have done a few others now, and they work really well.
Yes we sell them through my workshop. Ball park pricing is $5250 for crank, rods, pistons, rings. The crank is nitrided, balanced, and has a collar fitted, the rods are Eagle, the pistons are usually JE or CP.
I say ball park, because; there are a number of options; 22mm pin upgrade, plus all the usual custom piston options, plus as the pistoons are out of the states, with the dollar moving around a little latley it affects the price. Also rods are optional, Eagles, Crowers, Carrillos etc. So depending on what rods, and what piston options you want, the price will vary.
Below ill give a summary of the answers to the usual questions, but ask away if you want to know something
No, the crank is not as good as a brand new HKS, Tomei, etc. But for the majority of applications it is more than good enough. How many big power RB30's are out there with std cranks....
Yes the rod to stroke ratio is not ideal. The RB 26 does not have a good rod to stroke ratio to begin with, but the std rod to stroke ratio works on big power combos. Any stroker reduces rod to stroke ratio. I would prefer more capacity, with a slight decrease in rod to stroke ratio.
No this is not easy to do yourself. Im not just saying this so you buy one from me. I use a lot of different machines to do this
I decrease the stroke to 83.25 mm. This means it all JUST fits in.
My initial engine made just over 400rwkw, and reved to 8800. The most power i know of through one of these combose is a tad over 450 awkw.
In my OPINION these are a great thing for a streeter.
Hope any of this is interesting of useful to some of ya........
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
