Well i was thinking about putting:
Work Emotion XD9's Bronze [with the blue wheel nuts]
5-114.3 18X8.0 +35 [F]
5-114.3 18X9.0 +38 [R]
and a full Impul body kit front, side skirts and rear.
on this car:
Do you think it would look good or............? <---- Imput ideas :blink: Would love to hear it before spending some money on looks for this car.
Ideas like should keep the rear wing or get it removed? etc etc
Thanks for all the help and advice in advance
pics
:) :) :) :) :blink:
im a bit biased but i love black on black, so some black gt-c's with the silver lip (which would be a similar look to what you have now) would look hot,
There are a lot of fans of the impul kit out there, i like the impul side skirts, but think maybe a top secret front bar and possibly a do-luck rear, or even do-luck skirts and rear with a top secret front bar, either gtt or gtr style
big fan of impul here too (have the sideskirts) but IMO the whole kit looks best on a light coloured car ... on a black one you can't really see the curves/details on the bumper bar at all.
I've got a nismo (not nissan altia) rear bar, impul sides and nothing at the front atm .. thinking of getting this for the front but worried about clearance http://cgi.ebay.com.au/Nissan-GTR-Skyline-...%3A1%7C294%3A50
Oh and bronze wheels look great on a black skyline but I'd go for something with less spokes (5-6 tops) Check out the DTM Z7 Bronze wheels in the trader section, cheap, light and look great.
Edited by Delta Force
Any pics of 34 GT-T's with the DTM Z7's? Im interested :P
can also be abit more aggressive with the widths/offset of the xd9s..
As in? I thought the offsets / size i chose for the 34 would sit perfect with the guards?
Impul will look great man, on a black car the front bar looks a tad more aggressive in my opinion, impul sides and rear look very sleek and flow good. If i didnt have my ztune sides i would get impul. I got a top secret front bar and also id probably substitute for impul front if i wanted a different look.
Either get smoked or clear indicators
Wheels: im a fan of black on black also, but i think any quality jap wheels will set it off well. need good width and good suspension setup and ull be good to go. keep searching for different pics and go with what u love. All our opinons mean nothing in the end its ur car dude so make it ur idea. Just dont lose ur composure and put the massive trolley factory wing on!
P.S did u just buy that of the net? or are you the guy trying to sell it? cos ive seen that car on a couple sites for sale.
Check this out, i think it looks hot. id wack different wheels on tho.
yeh thats sexy, i don't know if i will keep the wing or get it removed. Im pretty set on my original decision though.
Im wanting to buy that car. And gonna change these 2 things strait away after i get it.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
