  • Replies 87
Yes the speed cut is gone and the rev limit has changed somehow, it doesnt seem to fuel cut anymore. Not sure if its higher tho, but it would be able to I think.
The ecu runs a standard map until full throttle where it dumps extra fuel. That is hard to get around apparently.
Highflow will definitely get you to 200, more if the piping was changed. Is it worth ripping the turbo out and running an aftermarket? Is there a high power housing that will fit? I dont mind fitting a new manifold, as I would make it myself.
Alloy bore so no extra size unless the whole short motor fits with the 2.5 heads. You would need better pistons and rods anyway so its only the block.
The standard ecu map is doing the wot fuel dump, its just finding the best way to bypass it.
I will ask if he minds me handing the map out, that should be fine. It should get you very close with no need to spend hours on the dyno.
sure ask him if its ok! i wouldnt run my car on your map, thats asking for trouble, but yeah it might help lose an hour on the dyno lol
i had a thought, the rev limit is a fuel cut, if the emanage is doing the injector pulsing, then its possible that the rev limiter can be moved...........
What power will the highflow allow? The flow is the problem. I would rather spend 2 grand on a HKS aftermarket im thinking, then run 76mm piping right through. Just means making new exhast manifolds and cutting up the dump I just had made.
And then a vq35 crank and rods....
Your on the same track as me!!!!
2nd motor 300awkw's at 15psi with monster torque....should be a cheep rebuild to a 3.5lt too!!....going to get the compression to about 8:1 as well.
thats all it is right? is it a block change? or does the standard block remain and only a vq35 crank and rods used from a 350z??
i'll get that dump back to you soon hopefully, have not forgotten about it
From what my motor builder is saying its the same block with different crank, rods and pistons.
Im pretty sure these engines have an alloy bore no sleeve. I think you will need the 3.5 block with aftermarket pistons to drop compression to 7:1 or so.
If the block is taller due to the stroke being longer, it may make the engine bay tight.
Mmm ive definitely caught the bug...
There is of course the GTR's vq3.8dett :/
Edited by scotty nm35
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
