well the ecu cut in my 33 was savage. like someone had jammed their foot on the brake for a second and then it kicked back in. that was at 15psi (about 1 bar). if you got to 1.3 bar then it's pretty safe to say that you don't have it
When you drive it that is..............
Yet to see her Bubba!
She was a daily driven 30 for nearly 2 years! Soon enough though mate, pulling the engine out tonight and putting it on the stand to strip it down and send to the machinist next week :iluvff:
Definitely miss her though, the laggy stag just doesn't quite cut the mustard :D
Edited by bubba
your AFM has a frequency range that it can measure.
it measures air flow.
14 psi = x amount of air flow.
17psi = y amount of air flow etc etc
once the amount of air going through is higher than the afm's limit, the ecu gets the message that it is getting too much air and the ecu adds more fuel..
so you get that misfire as it runs rich.
solution?
re-map of your ECU and an Z32 AFM.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
