remove the back seat, and then there is bolts in boot if u have child restraints and then it just basically pulls out.
remove the back seats first and u will c wat i mean. its not very hard, should take no more than 10mins
Edited by cheez
cheers mate
how do u take out the back seat btw?
the parcel shelf is part of the body, I assume you mean taking off the cover with the speaker grills
to get at the cover and remove it you need to take out the back seat
first start with the bottom of the seat you have to remove the two bolts that are on the outside, it can get tricky after that as there are metal brackets that clip in on the inside of the seat, you kind of have to push the bottom seat while also pulling up, when you get it loose you will see what I mean.
the back of the seats have another two bolts that will be exposed when you get the bottom off, once the bolts are off then a case of pulling the back up and out
then unbolt the child restraints and the cover will slide out
nah i didnt mean the hole covers i ment the hole parcel shelf so that i could put in some 6x9s and some moulds
but thanks for the help on removing the seats mate looks like im gonna have to do it with the parcel shelf still in there
thanks for your help mate
no dramas,
hmm I'm interested to see how you go with 6x9's, I installed fusion splits in my old gtt but they were the same size as the factory units and from memory if you want to fit 6x9s you might have to widen the holes in the parcel shelf with a dremel and make custom brackets or drill holes, the factory units use a plastic bracket that screw to the shelf hopefully if you remove those the hole left behind will be big enough
when you get around to it you will see how the parcel shelf is part of the bodywork, I'm sure someone has done this before, just maybe need to search on the forum for examples
good luck though :)
  • Like 1
cutting a rear deck for 6x9 is a defectable offense in SA, which would require lots of work to fix back to stock
plus 6x9 speakers dont sound as good as 6.5 inch in a decent brand anyway so why bother cutting the deck up?
my 2c
yea but if u go out and buy some speaker moulds u should need to cut nuffin because there would already be holes from the original speakers
i think the moulds look so much better than just the speakers sittin in the shelf anyways but thats my opinion
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
