Ok so a mate suggested to me the other day that since I am running standard injectors and fuel reg, that until I can afford to get a remap/Nistune RB20 tune done, that I should take out my Microtech LT10S (the usual overfueling, shit fuel economy, horrible cold starts, fouling plugs, the fact that WOT = smokescreen deployed, and a EPA warning letter on top of that!) and replace with a standard RB25 ECU (think its all wired up still into the R32 loom).
Now assuming that wiring is all okay, am I likely to run into any major issues from running FMIC, KKR 480 turbo (boost set to actuator pressure of 8 psi) and turbo back exhaust? The motor is a Series 1 Stagea motor, would I be any better off with the Stagea ECU or just a normal R33 Series 1 do?
I do have an airflow meter sitting in the intake pipe albeit disconnected, and the O2 & VCT are disconnected.
https://www.sau.com.au/forums/topic/280128-microtech-removal-questions/
hard to say, but personally I would think the only way you'll know for sure is try it. half of us will say it wont work, and the other half will say it will at the end of the day there is a sure fire way of knowing.....
So do you intend on connecting them? AFM you won't get away with, the other 2 yes, but it's going to run like shit without VCT and o2.
If you can sort out the wiring, then provided you stick to 8psi then I can't see a reason why it wouldn't work.
nah I will connect everything up, there are around 69000 R33's around here so I'm sure I'd be able to get a lend of one, its more fingers crossed that the loom hasn't been butchered, but I'm assuming that there's no major differences in fuel maps etc for Stagea vs R33?
Hopefully the ATTESSA *might* run with a stock ECU as well, but I'm not holding my breath.
Yeah it's mainly come about because I'm so sick and tired of the way the Microtech behaves, but then when you're travelling 400+km to get a decent tuner it's not a cheap exercise at all.
  • 1 month later...
spose ill do a bit of an update; finally got a stock computer, threw it in, hooked up AFM... and nothing! I'd forgotten that the Microtech had a relay set up in the boot for the fuel pump so stock computer wouldn't prime! I'll be getting a mate to rewire it for me in the near future, then we'll see what happens...
the stagea ecu is remappable with a type 4 nistune board andif tuned right passes all the epa tests.
nah gonna sell it to some sucker with a dirty 30 or a rotary owner :)
URAS: I thought that the type 4 board was only compatable with the NEO ECU? That's how I read the Nistune website anyway. Mine is a Series 1 Stagea motor with the old school RB25 and ignitor module.
ah yep ser1 needs the z32 ecu trick, sorry should have read your post better sorry.
will likely not bother with Z32 and just go RB20 remap and ditch the VCT since I already have a stock RB20 ECU lying around.
best running a jaycar switch then, ive got some dyno tests i did here with and without the vct and the hole in the mid range is about 15-19rwkw deep....
  • 6 months later...
might bump this up again since I'm once again looking at this, I have no idea if the standard plug is for the R32 or R33 ECU, will this matter? when I plugged in the R33 ECU the fuel pump refused to prime, however there is a relay type thing for it in the wiring in the boot, would i need to circumvent that?
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
