Hi fellas,
I just bought a set of original 18" Nismo LMGT4 black rims. Although they look ok without the centre caps - I prefer them. Does anyone have a set they want to sell or know of a place that sells them. I don't mind something that is after market or even just plain black just to cover up the centre gaps.
I have tried places like J-Imports and they want like $350 for a set of 4 originals which is fair enough, but I just want something to cover up the centre caps and not fuss about looks now as long as they are in black.
Your help would be much appreciated.
PS: A few of my mates suggest just spraying the centre gap area black and it would blend in - anyone done this?
A few things:
Be careful because on some of the Volk rims the flat caps (the ones in the first photo) don't clear the wheel bearing cap on some rims.
It is common to lose the damn things when you kerb hop at the track.
You can get them from Greenline/Nengun etc cheaper.
It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin.
A few things:
Hey mate,
Thanks for your reply.
I kinda think having no caps looks kinda tough. What do you mean by: "It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin?"
Do you have an example picture or something?
Thanks mate.
Cheers,
Kevin
I dunno, not like I have any idea what I am on about. :)
If you look at the photo you will see my pos. Bearing cover is missing paint, hub is a lovely shade of iron oxide & the open ended nuts are bleeding red where they exposed metal on the studs & then got wet.
So yeah, tough in a adandoned shopping trolley kind of way.
You can remove the bearing cap & paint or anodise that. Then use a shiney new split pin. Also the hub centre can be cleaned up & painted a bit too.
Or just get some caps & stay away from the kerbs & carparks.
Edited by djr81
I dunno, not like I have any idea what I am on about. >_<
Ha ha ha.... I get ya now bro... :)
I think I will just spray it black and leave it... although I would prefer to have the caps - they're just so blood expensive.
You got any idea where I can get some cheap non-branded caps from?
Cheers,
Kevin
if you have any luck with original ones at a non ridiculous price let me know please, I'm in need of 2 bronze flat style caps.
cheers, tim
Yeah will do - still frantically looking for mine. ;)
Guys try Nengun....or Powereplay imports but they can be expensive.
Im pretty sure nengun have different types such as "Rays" or "Nismo"
Thanks mate... yeah, they would but would be expensive... I just cannot just paying like $400 for 4 centre caps.
This is what your after.....
http://www.nengun.com/rays-engineering/lmgt4-center-caps
Does anyone have a picture of the 'high type' caps? I've got a feeling the flat ones look better!
This is spot on what I am after. Thanks mate. $35 each is not that bad...this I can definitely afford.
What do you think looks nicer - those flat ones or the badgey looking ones?
Flush ones do look better but they may not fit. You need to check.
Yeah, that's exactly what I am worried about...I'm not going to pay like $200 for a set of centre caps only to find the damn things don't fit. Can't really ask the seller for a refund just because I wasn't sure in the first place.
I do like the bold ones, but don't know if it would stand out too much.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
