Hi fellas,
I just bought a set of original 18" Nismo LMGT4 black rims. Although they look ok without the centre caps - I prefer them. Does anyone have a set they want to sell or know of a place that sells them. I don't mind something that is after market or even just plain black just to cover up the centre gaps.
I have tried places like J-Imports and they want like $350 for a set of 4 originals which is fair enough, but I just want something to cover up the centre caps and not fuss about looks now as long as they are in black.
Your help would be much appreciated.
PS: A few of my mates suggest just spraying the centre gap area black and it would blend in - anyone done this?
A few things:
Be careful because on some of the Volk rims the flat caps (the ones in the first photo) don't clear the wheel bearing cap on some rims.
It is common to lose the damn things when you kerb hop at the track.
You can get them from Greenline/Nengun etc cheaper.
It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin.
A few things:
Hey mate,
Thanks for your reply.
I kinda think having no caps looks kinda tough. What do you mean by: "It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin?"
Do you have an example picture or something?
Thanks mate.
Cheers,
Kevin
I dunno, not like I have any idea what I am on about. :)
If you look at the photo you will see my pos. Bearing cover is missing paint, hub is a lovely shade of iron oxide & the open ended nuts are bleeding red where they exposed metal on the studs & then got wet.
So yeah, tough in a adandoned shopping trolley kind of way.
You can remove the bearing cap & paint or anodise that. Then use a shiney new split pin. Also the hub centre can be cleaned up & painted a bit too.
Or just get some caps & stay away from the kerbs & carparks.
Edited by djr81
I dunno, not like I have any idea what I am on about. >_<
Ha ha ha.... I get ya now bro... :)
I think I will just spray it black and leave it... although I would prefer to have the caps - they're just so blood expensive.
You got any idea where I can get some cheap non-branded caps from?
Cheers,
Kevin
if you have any luck with original ones at a non ridiculous price let me know please, I'm in need of 2 bronze flat style caps.
cheers, tim
Yeah will do - still frantically looking for mine. ;)
Guys try Nengun....or Powereplay imports but they can be expensive.
Im pretty sure nengun have different types such as "Rays" or "Nismo"
Thanks mate... yeah, they would but would be expensive... I just cannot just paying like $400 for 4 centre caps.
This is what your after.....
http://www.nengun.com/rays-engineering/lmgt4-center-caps
Does anyone have a picture of the 'high type' caps? I've got a feeling the flat ones look better!
This is spot on what I am after. Thanks mate. $35 each is not that bad...this I can definitely afford.
What do you think looks nicer - those flat ones or the badgey looking ones?
Flush ones do look better but they may not fit. You need to check.
Yeah, that's exactly what I am worried about...I'm not going to pay like $200 for a set of centre caps only to find the damn things don't fit. Can't really ask the seller for a refund just because I wasn't sure in the first place.
I do like the bold ones, but don't know if it would stand out too much.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
