Hi guys,
got the car wheel aligned today here in brisbane from bridgestone select, done an awsome job. We settled for Rear left +1.14degree Rear right +1.29 and both toeing in 2.7mm which under full squat the car will pull the rear wheels back to 0 degree and 0 toe, so should hook up good.
Front left -1.83degree and front right -1.46degree, front toeing in 0.8mm and got the caster sorted aswell, because the left front was hanging back the right front was pushed foward, so thats all good now too.
I am a little worried about the amount of toe on the rear as it does seem like alot.
After looking at that video, it doesn't look like your getting enough rear droop to zero out your ass end after the initial launch... Spring rates, compression and weight transfer looks pretty good though.
I'd hate to see the car start getting sketchy in the top end for the sake of marginally more traction (that you may not need).
Must be a blast to drive!
Justin.
The Japs were going faster in the late 90's with H-patterns?
They probably were...it's been a while :)
Definitely fastest/quickest H-pattern street GTR either way.
Looks like there is plenty left in, too.
Hi Guys, Just driving home back to Mackay, I will put the link on the 8.97sec pass up. Also Theo Willot Still holds the World record for fastest H pattern GTR I missed out by .02 of a second, and on Sunday I was gona to smash that time with an ET of 8.8. But third gear smashed into a million bits. I was 3MPH faster by half track than my 8.97 and thats also lifting of cause 3rd blew up. We are under the impression that the selector fork has bent therofore only half engaging 3rd and stripping the teeth off the cog.
Im laying down the challange that this car will run a Mid 8.5sec pass or lower with this H pattern box, as I am only running 150MPH to get 8.97secs and theo done 8.95 at 162MPH, I am only currently running 900-950HP with alot of go juice up my sleeve. Haha.
I will upload the other video my GF filmed later tonight when we get home,
cheers Matt
There is no evidence of a Japanese or American or euro or pommy GTR even running the 8s with a H pattern box, me and theo are the only ones to do it, Yes there are plenty of GTR in the 8s and 7s but they all run Sequential boxes or Airshifted liberties or Lenco gearboxes, which are an easy 0.3 of a sec quicker. Thats why Theos time is a World record that himself or me could ever find recorded.
Yes, how could I forget Theo's time....I don't think it was registered though :D
Either way, fantastic result and hope to see it get close to [RH9GTR]'s 8.47 auto time
btw, what does the car weigh in race trim?
Check out these videos... There are several running 8's with H-patterns
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
