  • Replies 340
Posted Images
I had to get another crank after my first rb30 because the clutch pressure was too much on the thrust. The machinists say this is common with supra and skyline cranks as the clutches we all like to use have huge pressure ratings.
Easiest way to avoid it? Don't sit at lights with the clutch in just waiting while other cars go. Only use the clutch when you have the green. It takes some getting used to but then it's second nature
I dont have pics atm but who ever did the machine work on the crank should be shot!
They drilled the crank to balance it...but punched a hole through the side of 2 counterweights! and didnt bother to clean up the large metal shards...so i could just rub my thumb over them the chunks of metal would come off.
also found cracks in the ring lands on 3 pistons and the rods look junk due to the same dodge machinist.
Ill get some photos of the thrust bearings aswel, because I lol'ed when i could move the crank back and forth 5mm.
So Im up for an entire rotating assembly for an RB30, might be a while before its done, but it will be done well
Turns out the motor was even worse then I thought! Hence the price.
And Titan, what machinist? I don't have a machinist, and I don't machine it on my own either.
Let me see what these other 2 RB30s are like when I strip them down, and see if I have anything to offer.
Edit: Steveo, thanks for the advice... Will have to remember that in future, it had a 1250KG pressure plate in it too...
I had a good chat with Greg at Proengines at lunch time today.
He said that the holes in the side of the crank counterweights are factory! lol.
Also had a good chat about trying a few things with the cylinder head and stuff, So hopfully Ill have I hell of a decent engine in around 12 months.
He also said any gain in response by using high comp pistons is lost in peak power due to not being able to run much timing on boost.
So looks like Mahle flat tops and a 1.3mm headgasket are the go, with a bit skimmed off the head to remove the pock marks.
hint hint, WMI + high comp pistons = win.
if you're still looking at running E85 this will be a null point as so many people can dial in timing past the max timing for power mark...
E85 wont happen until I can get it here in Canberra from a bowser so prob around 2 years or so,
Do you have any pictures of how it all looks? How bad was it really?
No pics as yet, ill get some tonight,
But the thrust bearing has streamers of metal hanging off it and the #2 bearing is squished flat. and the forward thrust face on the crank is badly chewed up.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
