  • Replies 340
Posted Images
mines snow performance. its got a MAP sensor in the control box under the bonnet, when it hits XX psi it starts injecting and by XX its on full so it ramps up the pump based on boost so you arent injecting silly amounts all the time.
water meth injection, its not expensive and gives similar/same results as using E85.
And E85 is cheaper then regular ULP when you buy it at the pump... Runs cooler... You only have to worry about keeping one tank topped up... No extra weight...
Remember, WMI also increases your compression again... So if you go super high CR, you're at risk of bending shit.
i am not saying E85 is a bad fuel but in Canberra you cant get it at the petrol station and you cant get it in Goulburn, there is not enough demand for it to be put in considering the relatively small spread out population when you look at Melbourne with 2 stations covering the whole place.
E85 does have negatives too, it uses 30% more for the same power figure (which brings it inline with 98 prices), requires a much larger fuel system to support it, it cant be left for too long as it absorbs water (granted petrol also goes off if left too long), have to keep an eye on your oil as it can contaminate it if the engine isn't running long enough to get the oil up to temp.
WMI with a sufficiently sized tank (like my 9.5L tank) can go for months without checking (street driving though 9.5L is still a lot for track driving) even the smaller tanks last a fairly long time unless you have your foot in it everywhere you drive. WMI also cools the intake charge like E85 does and when setup correctly you can even go so far as to run 91ron petrol and still make good power. (in some cases remove the intercooler completely as well)
there is a new project for you when you are done with the supra steve, 4wd twin turbo V8 skyline.
Haha that would be pretty special! Someone has done that in an r33 gtr in Europe, I think. It was Denmark?
Next for me is the Ultima, v8, 7.3L, 990kg
Nah nothing as exotic, Eagle stroker in an LS Chevrolet block
Now you mention the Zonda motor I'll look up specs just for a laugh
It will have the lightest rotating assembly as possible though
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
