Hi Everyone,
I am looking at upgrading my fuel injectors on my R33 (Series 1) RB25DET and not sure whether to go for the Nismo 555 or 740s.
Is there any disadvantage of using the 740s, even though my current application doesn't come anywhere near using their full potential? Why I am asking this question is that the 555 and 740s are similarly priced, and I thought that rather than buying bigger ones in the future, I would get them now.
Any issues regarding idle, drivability, fuel consumption etc?
Relevant supporting mods are:
-Power Intake
-Z32
-Nismo Fuel Pump
-Power FC
-3" Exhaust
-FMIC
-EBC
Thanks!
Peter
Edited by Peter
https://www.sau.com.au/forums/topic/281288-nismo-555cc-or-740cc/
Well what future mods do you have planned?
You dont even have a turbo yet by your mod list... 550's will do well over 300rwkw, so unless you want more, dont get 740's.
As for economy - you dont own a modified turbo car, and then worry about how many km's to a tank
Have to agree here. You would stick with the 555's if 300kws is where your headed but otherwise the 740's if your going for a monster that can't put the power to the ground anyway. 350kws or over is just stupid in a street car so decide now where your headed. Though 740's would come in handy should E85 make a big entrance to fueling in the future.
740's are a little more difficult to tune but if the tuner knows what he's doing should achieve a good result.
I have got 740cc's running in my car at the moment.....New turbo is on its way and only looking to push about 270rwkw or so.....
The only reason i got my 740cc's was because i picked them up in fuel rail for $600 delivered....and 555's were at the same mark....it doesnt really hurt having bigger injectors well 740's compared to 555's....if you can afford it then 740's are a good investment as you might wanna chase up more power in the future....do as it suits you mate
740's
i'm pretty close to running out of puff on my 555's with 320ish rwkw
550cc Injectors at 3bar base pressure will support 350rwkw on pump98 (BSFC=0.55) - so I would be checking your fuel flow or the tune or your regulator!!!
550cc Injectors at 4bar will support 400rwkw on E85 (BSFC=0.6).
Can you see yourself making more horsepower than this???
I would always select the samllest injector for the required horsepower in allmost all situations.
My opinion only , if the price is the same and there is no real disadvantage , the 740's leave more possibilities open .
The Nismo 740 is a single pintle injector with a four hole wafer in front of it so the spray pattern is supposed to be very good for an injector that's twice the size of the std 370's .
To me going this way means you have the capacity to make high power outputs with all of the rest of the fuel system running in factory type regulation - provided the fuel pump can keep up . Won't need adjustable FPR's and it can all look factory standard .
I think the real question is can the engine management system run largish injectors and have fine control of them .
I think it was Sk that told me the computer has to have a fair amount of processing power to have fast accurate control of injectors particularly at light loads and lowish revs - normal round the burbs stuff . People say PFC's cope fine with them .
I bought 555's and then 740's because I got interested in the possibilities of E85 - still in their boxes .
Cheers A .
Thanks for all the replies...I think discopotato03 summed up my question better than I originally asked it...
At the moment the price difference between the 555 and 740s is $6.27 per injector or $37.62 for all six....buggar all really...so my way of thinking is that if I can get bigger, for basically the same price - why not?
It was mentioned that the 740s are slightly harder to tune...are there any other disadvantages?....(because besides that, people seem mixed in their views - some people say go for the smaller injector - why?)
If my car will drive basically the same with the 740s or 555s, I might as well go for the 740s as it leaves more possibilities open in the future...
I am more than happy for alternate views...
Thanks!
Peter
Edited by Peter
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
